Stock Battery & Kinetik in the Rear.
Okay, so I had purchased a Kinetik 1800 and I went to go install it up front last tuesday, but it happened to be a good 4" taller than my stock and I'd have to literally bend my hood to even make it fit.
So I decided I was going to go ahead and run it in the back.
Well, my second ANL Fuse should be here tomorrow morning.
I plan to from it parallel from stock to kinetik in the rear with the 2 ANL fuses in between the two.
My question is, is this a terrible idea & why? Are there other options? ( will not bother with an isolator as I find it to be an incredible waste of money & at that point I'd rather buy another battery. )
I have more important things to worry about, so the purchase of another battery is kind of out of the question.
Edit: Keep in mind that my car comes with a stock 150A alternator.
Edited by Semper
New Setup;
H/U; Pioneer DEH-80prs.
Wiring; 2 runs of 2/0 OFC & Big 3.
Subs; 2 D1 DC Level 4s.
Monoblock; DC 3.5k.
4 Channel; JBL GTO1004.
Highs; Vifa NE25VTS-04.
Mids; Aura NS6-255-8A.
Alt; 160a.
Batts; Optima, KHC1800.
itll be ok... best advice is to keep a good charge on the kinetic at all times.. its not ideal but it will work
151.6 with single 12 at 41 hz
153.2 with 2 12's at 43 hz
power: dd m4
I've been seeing shit about charging & whatnot.
Why wouldn't it stay charged? Like, what exactly is keeping it from staying charged.
Someone said in another thread that their battery dies within a day. Why isn't his alternator pumping juice to it?
New Setup;
Monoblock; DC 3.5k.
Alt; 160a.
if your battery is dying within a day you got issues lol big issues..and its always good to keep your batts topped off especially with a stock alt and stock batt..its good for the health of the batteries... alts arent perfect at charging batts...theres a thread (its stickied at the top of this section) that explains it in more detail
power: dd m4
Wasn't me with the battery dying in one day issue.
So if alts aren't perfect @ charging batteries, what would be recommended to keeping my kintetik topped off?
New Setup;
Monoblock; DC 3.5k.
Alt; 160a.
ive got a battery tender charger type deal i bought from orielly's...i honestly dont remember the name of it and im letting a buddy use it to charge his batts up.. basically an automatic shut off charger that can charge agm batteries is what you want
http://www.stevemeadedesigns.com/board/topic/135645-reminder-alts-are-not-perfect-charge-up-your-bats/page__fromsearch__1
^^ that thread would be a good read for ya
Edited by pa-pa-platypus
power: dd m4
Okay, but in the mean time my alternator will pump juice through my stock & into my Kinetik?
Should be suffice until then, right?
Edit; Also, thanks guys. I can now rest easy tonight. ;p
Edited by Semper
New Setup;
Monoblock; DC 3.5k.
Alt; 160a.
of course...just make sure you ground the back batt in a good spot with bare metal and should be fine until you can get a charger... just keep an eye on your voltage.. whats the kinetic resting at right now?
power: dd m4
  • Who's Online   0 Members, 1 Anonymous, 791 Guests (See full list)
