new guy Posted July 4, 2012 Report Posted July 4, 2012 if you cant hear your system from outside your car, there is something wrong. 2 10inch subs will easily be clearly audible from outside of your car not necessarily true i have 2 skar vvx 12s off 1700 watts sealed off from the trunk in my mustang and with the windows up i can barley hear it from outside my car, even though my rear windshield flexes a good inch. the only sound deadining i have is about 3 square feet on my drivers door. and OP please post pics of setup, box dimensions every bit of info on your setup. the more we know the more we can help you. *current* 1991 honda crx si 2 skar audio 12s pioneer 6.5s dual 400 watt amp audio technix db 1/0 wiring kit. dual head unit
purplesyrup Posted July 4, 2012 Report Posted July 4, 2012 if you cant hear your system from outside your car, there is something wrong. 2 10inch subs will easily be clearly audible from outside of your car not necessarily true i have 2 skar vvx 12s off 1700 watts sealed off from the trunk in my mustang and with the windows up i can barley hear it from outside my car, even though my rear windshield flexes a good inch. the only sound deadining i have is about 3 square feet on my drivers door. and OP please post pics of setup, box dimensions every bit of info on your setup. the more we know the more we can help you. I was under the impression that his windows were down. I know what you mean The way he is describing it, its seems like he is not getting hardley any output
Gnarkill Posted July 4, 2012 Author Report Posted July 4, 2012 i have done some test playing with the subs today and to me i sounds like i dont have power enough. but the subs are not that big on power so im not sure on what to do. can any one maby give advice on a good amp to drive my mtx thunder 6000 subs? and some good 10" subs
purplesyrup Posted July 4, 2012 Report Posted July 4, 2012 i have done some test playing with the subs today and to me i sounds like i dont have power enough. but the subs are not that big on power so im not sure on what to do. can any one maby give advice on a good amp to drive my mtx thunder 6000 subs? and some good 10" subs arent you running a 1000w RMS amp? I think those subs are 300w RMS each, you should have more than enough power how are your subs wired, what ohm load do you have them wired to I think your like impedance is extremely high, or somthing huhuh can you take any videos of the subwoofers performance and put them on youtube, then post a video on here?
Gnarkill Posted July 5, 2012 Author Report Posted July 5, 2012 It says in the manual that the amp is supposed to hae 2000watt max at 1ohm, i have wired the subs so when i measure the speaker cabels at the amp is 1ohm. I kind of want more power/ force to the bass. im going to take a video today and try to post it here.
purplesyrup Posted July 5, 2012 Report Posted July 5, 2012 It says in the manual that the amp is supposed to hae 2000watt max at 1ohm, i have wired the subs so when i measure the speaker cabels at the amp is 1ohm. I kind of want more power/ force to the bass. im going to take a video today and try to post it here. cool lets see it,, ill be up for a bit
Gnarkill Posted July 5, 2012 Author Report Posted July 5, 2012 Does anyone have any experiance on DVC 2ohm subs?
safiend Posted July 5, 2012 Report Posted July 5, 2012 Don't see why yall beat around the bush. If you like it, then keep it. But no, you don't have a "good" system. Keep messing with it first and learn more about it before you decide to upgrade, and if you do.. go sundown. :] New build coming soon..
Crandis16 Posted July 5, 2012 Report Posted July 5, 2012 what is smd tech in an amp ? I think he was talking about SMD LEDs inside the amp????? It looks like the inside has LEDs anyway My Red zx2 Build Log My Black zx2 Build Log My Red zx2 UBL
Crandis16 Posted July 5, 2012 Report Posted July 5, 2012 Does anyone have any experiance on DVC 2ohm subs? I do. wire it to 1ohm by wiring in parallelEdit: I didn't see how many subs you're running My Red zx2 Build Log My Black zx2 Build Log My Red zx2 UBL
