Mechman Alternators
GET RID OF THE BATTERY LIGHT
I'll sit and wait for the update ;)
no luck.... I checked pretty much every fuse, I even found why my cigarette plug wasnt working but I can't find the alt problem
Here's the alt installed
As you can see all the plugs are correctly installed, I double checked and I have the yellow wire attached to the positive bolt, I double checked it was getting a charge with DMM
Scion tC SQ Build
iPad mini, lots of fabrication, daily driven
Ford Explorer C Pillar Wall Build
Just a cheap car to destroy with bass :D
Did they say on the Scion forums if there was a "reset process" that you have to go through?
no, they said I could take it to pep boys or some place like that with a scanner that can reset the system, the only other way to reset is to unplug the battery for 30mins-an hour iirc because after that my car usually runs a bit different until it sorts its self out.
Scion tC SQ Build
That would be the reset process I was talking about. After a certain amount of time with the battery disconnected, yours being 30 minutes to an hour, hook it back up and the entire system goes through a "relearn procedure", checks all system codes for actual malfunctions and all that stuff.
It's worth a shot to take it up there. Just hope they use an actual modis and not just a regular pocket scanner.
