I have a quick question to see if my idea will work.
I have 2 DVC 4 ohm subs, and want a 2ohm load from each one to my amp. So I was wondering if I have a box built, and have each sub with it's own terminal cup will it still work that way?
My amp is a monoblock with 2 sets of outputs, at 2ohm it outputs 1200watts rms, and it would be perfect for my subs which is why I'm wondering this.
it will be 1 ohm
2007 Ford Ranger
(ALL YET TO BE INSTALLED - DUE TO WORK SCHEDULES)
K&N Performance Air Intake
Massive Audio D2400 Mono Amplifier
2 Custom Built 8" Subwoofers in Ported Enclosure
Pioneer AVH-P4400BH In Dash Double Din DVD Player (Video Bypassed)
4 - Pioneer TS-A6886R 6" X 8"
2 - SMD Heavy Duty Single ANL Fuse Blocks
2- Stinger SPP1200 Dry Cell Batteries
JL AUDIO Interconnects
2/0 Gauge Big 3
ILL Customz 8 Spot Flat Lug Style Bolt Down Terminals
ILL Customz 1/0 to 4 Gauge Power / Ground Reducers
Factory Alternator
__________________________________________________________________________________________________________________________________
2002 Cheverlot Monte Carlo SS - (Deceased)
2 - Rockford Fosgate Power 1501BD
1 - Rockford Fosgate Power 851x
Rockford Fosgate Power 6 1/2 Components
Rockford Fosgate Power 3 way 6x9
2 - JL Audio W7 13.5" Subwoofers (Sealed)
Pioneer AVH-P4400BH In - Dash DVD Player
Pioneer AVIC - U250 - Add-on GPS Navigation System
Audio Control 6XS 4 Way Crossover / Line Driver
Ohio Generator 200 Amp Alternator
3 - Stinger SPP1200 Batteries
1 - Optima D34/78 Battery
nope. you're wiring two dual 4 ohm subs in parallel to a monoblock amp (single channel amp) so the amp will see 1 ohm
So because it's a mono it still would see a 1 load, but if it was a 2 channel each channel would see a 2 load?
monoblock would see 1 ohm. 2 channel would see 2 ohm in stereo. if you had to use a 2 channel for subs, i'd bridge it if possible
when you hook up two subs to a monoblock at 2 ohms each, the amp internally bridges them to a 1 ohm load.
SUBSCRIBE AT YOUTUBE! 18abVFL < CLICK!!
2005 Subaru Impreza
My build log.
Head unit- Kenwood Excelon KDC-X695
Front doors- Rockford Fosgate 6.5" Prime components
Rear doors- Rockford Fosgate 4" Punch coaxials
Sub amp- Audiopipe AP18001d
Subs- Two American Bass TNT 10"s
Box- 2.6 cubes @ 34hz, 36in of port
Big 3 & run of Raptor 1/0 to rear powercell
TEAM 808 UPSTATE NY.
Can it be heard 2 blocks away, thats how i rate systems.
  • Who's Online   0 Members, 0 Anonymous, 2296 Guests (See full list)
