Andy Paterson :P Posted July 8, 2012 Report Posted July 8, 2012 Hey guys, this is my first post on here so go easy I have an RE audio DTS 1000.1 amp and two RE audio SRX10D4 woofers id like to power off of it... now the amp has two outputs and the specs say = RMS Power (4Ω@14.4V): 330 W x 1 RMS Power (2Ω@14.4V): 560 W x 1 RMS Power (1Ω@14.4V): 800 W x 1 the woofers are 300 W RMS and id like to run them at 4Ω but this is where i get confused. Can the amp power two woofers from each channel at 330 W or just one? Cheers Andy
SojiaRaggs9000 Posted July 8, 2012 Report Posted July 8, 2012 RMS Power (4Ω@14.4V): 330 W x 1 that means if you wired both subs to it they would each see 165 * Eclipse CD3200 with PAC SWI-CAN2 and SW-ECL2 Steering Wheel Controls Interface* Pioneer D-Series Mids and Highs ( Fronts: TS-D1702C; Rears; TS-D1702R and Dash; TS-D1002R )* Rockford Fosgate PBR300X4 ( Mids and Highs Amp )* DC 3.5k with Dual Inputs; Custom Plexiglass Backing ( Sub Amp )* Rockford Fosgate Balanced Line Driver * One FULLY LOADED ~ 10" DC m2 XL* Custom Built Carpeted Ported Box Tuned to 32hz. Single Chamber With Volume of 1.44618³ ft ; 1.13216³ ft After Displacement* Custom Built Carpeted Trunk Wall with Added Fans for Amplifier Cooling* MechMan 240a High Output Alternator * KnuKonceptz Krystal Kable RCA Cables* Upgraded Electrical With 1/0 KnuKonceptz Kolossus Fleks Kable and 1/0 Sky High Car Audio Cable* Five Exide Orbital ORB34M Marine 12 Volt Batteries* PowerMaster XS D3100 12 Volt Battery My 2008 Chrysler 300 Limited - SuperCharged 3.5L V6 - UBL My Old 2005 Ford Taurus - CarDomain - Vehicle Was Sold
Andy Paterson :P Posted July 8, 2012 Author Report Posted July 8, 2012 So in order to power these woofers i would need an amp that had at least 600 W @ 4Ω...
Shankkilla420 Posted July 8, 2012 Report Posted July 8, 2012 RMS Power (4Ω@14.4V): 330 W x 1 that means if you wired both subs to it they would each see 165 Wait.. it's a monoblock, if he paralleled it it would be a 2 ohm load right? So each sub would be splitting 560 Watts. At least, I think so..
onyx1silverado Posted July 8, 2012 Report Posted July 8, 2012 if he wires each sub to 2 ohms then down to 1 ohm he'll get the supposed 800 watts. (in a perfect world) http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qty=2&woofer_imp=4 Pioneer AVH-P4200DVD Rockford Fosgate T5001 bd-cp 2 DC level 2 12's Focal Access Components in the front Focal Access Coax in the rear doors Rockford Fosgate Punch Boosted Rail 4 channel rms 4x75 XS Power D3400 under the hood Knuconceptz Ultra Fleks Power & Ground
Andy Paterson :P Posted July 8, 2012 Author Report Posted July 8, 2012 what i dont understand is if these figures mean per output or overall between both outbuts...
Bship Posted July 8, 2012 Report Posted July 8, 2012 there is only one output on a monoblock amp. Those extra terminals are just there for convenience when you wire up your subs. here is your wiring options http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=41#results CARS 14 Sierra crew cab daily, Small build coming one of these days 69 C-10 fleetside in many pieces, won't be done till the end of time Last car '12 Focus with build log http://www.stevemeadedesigns.com/board/topic/165619-2012-focus-btl-15-crescendo-sundown-audio-control/
