TLEJ Posted July 8, 2012 Report Posted July 8, 2012 If I have a box, designed at 33hz, then how do I set my amp? http://www.sonicelectronix.com/item_22195_Image-Dynamics-Q600.1.html Q Series Monoblock Class A/B Car Amplifier RMS Power Rating (14.4V):4 ohms: 250 watts x 1 chan. 2 ohms: 400 watts x 1 chan. 1 ohm: 600 watts x 1 chan. [*]Optically isolated MOSFET power supply [*]LED power indicator [*]Variable bass boost (0 to +12 dB bass boost at 45 Hz) [*]Soft Start Turn-on [*]Mono channel operation [*]Remote bass level included [*]Bridgeable Capability [*]Bi-Polar High-current output devices [*]Auxiliary full range output [*]Two-layer PC Board with heavy 2 oz copper [*]Massive ground planes and precision caps [*]5-Way System Protection circuitry [*]Heavy duty aluminum alloy heatsink for extreme heat dissipation [*]Nickel-plated RCA level inputs [*]Nickel-plated screw terminals [*]Input sensitivity: Low level: 200mV-6V[*]Variable low-pass filter (50-250 Hz, 12 dB/octave) [*]Variable subsonic filter (15-45 Hz, 12 dB/octave) [*]Frequency response: 10-20,000 Hz [*]Signal-to-Noise ratio: 98dB [*]Dimensions: 17-3/4"L x 8-1/2"W x 2-1/4"H [*]4-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier. [*]Authorized Internet Dealer [*]1-year Manufacturer's Warranty Low-pass? Subsonic? What's the difference?
Trey_Dog650 Posted July 8, 2012 Report Posted July 8, 2012 subsonic rolls off the lower frequencies. so if you set it at 25 then it rolls off at 25 or lowers. Low pass rolls off the higher frequencies, so if you set it at 80 it will begin to roll off at 80 or higher I could be wrong tho... 13 Kia Forte Build! 07 Hyundai Accent Build ***Super Seller*** N8ball2013 And then he gets to say ok all you guys were right. im sorry for being a dummy poo poo head.
TLEJ Posted July 8, 2012 Author Report Posted July 8, 2012 I under stand a high/low pass together, but maybe it's the same with sub-sonic and low?..
Sonic Posted July 8, 2012 Report Posted July 8, 2012 subsonic generally set a few Hz below the tuning freq of your box to prevent lower frequency to going to the sub which can present damage. It's like a high pass filter for your sub. Low pass generally set between 50 to 80 Hz, frequencies from that point down goes to the sub. hence, the sub can be said to be in band pass playing the frequencies between the two filters.
