Building system. Thoughts. Also maybe answer a few Q's for me!
Radio: Pioneer 80PRS
Wire: Rockford 12awg (speakers) and 0awg Rockford power and ground split at distribution blocks to 4awg to the amps.
Speakers: Doors/Rear Deck - Speakers will just be using stock locations (not going crazy with 20 speakers in the car!)
Here is where im lost. WHAT MIDRANGES SHOULD I GET?
Im looking for loud and clear! I have sort of narrowed it down to two brands/models. (Not sure whats better!)
Massive Audio M6M mid range, or Crescendo PWX-6
with whatever midrange i decide to get they will be ran with a 2-way crossover from aJL Audio C5 component set with SoundStream TWT.2 tweeters
These^^^ will be powered by a Planet Audio BB4.150 using Stinger RCA's
Subs will be two Fi Audio SSD 15"s with all options in a sealed box powered by an American Bass PH-4000 MD using Kicker RCA's
Also will i need a larger battery/alternator for my Chevy Cobalt to do all this?
Im not too sure on that amp i think it says 4k at 1the ohm buts its only like 270$ i doubt it would nake rated. You will def. Need the big 3. I would suggest the crescendo mods over the others
04 dodge dakota ext cab 4x4
excessive amperage 300 amp alt with MONSTER stud =)sundown z v3 15 in a 4th order on aq2200sundown 100.4 2 way active...2 Prv audio 6mb200 & 2 re XXX tweetersdeka intimidatorkenwood x396big 3 1/0 knu wire back to deka intimidator
It says 4 k max and 2 k RMS, RMS are the only intrestting amp watt´s.
If you have the money a 200-250 amp alt would be nice and a second batt.
"in the abundance of water, the fool is thirsty" Bob Marley
Lol im well aware of what rms and peak means... i only said that because i saw the description on ebay just being leary
If you are going to stick with a sealed box I say save a little bit and buy fi Q's with the High QTS option. Should get what you are looking for, only a little bit more expensive.
  • Who's Online   1 Member, 0 Anonymous, 1151 Guests (See full list)
