More power more cubic feet?
yeah a bigger box would be better for less power i guess. but it would make more sense to me that more power would mean a bigger box would be better
More air for the driver to move compensating for the extra power and the box will not be so boomy. But it is just a theory
More power=smaller box, because the sub is going to be pushed past its mechanical limits, and the smaller box helps out on the mechanical part of the sub (not bottoming out, etc)
Less power=bigger box, since the sub won't be pushed to its max, take advantage of the larger enclosure to get more output, but if you do this with overpowering, goodbye woofers.
Like I said in a previous post - the issue is that you don't just lose efficiency/gain power handling with a smaller box, you also lose low frequency response and cause a larger peak above the tuning frequency.
The best bet for a daily music box is still to design it based on the driver and the goals you have, and then don't drive it past the mechanical or thermal limits. In most cases, the efficiency makes up for the decrease in mechanical power handling. If you can't do that and get the output you want, look for a different sub or use multiple subs.
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
Profoundly stated
  • Who's Online   0 Members, 0 Anonymous, 1120 Guests (See full list)
