wilcox81 Posted July 11, 2012 Report Share Posted July 11, 2012 I have 2 audiobaun 15" aw 1500x ill be runn 1600 watts to them going in a s10 blazer any ides on box design? Quote Link to comment Share on other sites More sharing options...
Joe X Posted July 12, 2012 Report Share Posted July 12, 2012 Post your max dims, amp, subs models. Quote Link to comment Share on other sites More sharing options...
wilcox81 Posted July 13, 2012 Author Report Share Posted July 13, 2012 Ok again i have 2 audiobahn aw 1500x 15" 800rms 1600 peak. ill be running around 1600 watts to both of them for now. my max dim are 38'w-18"h-24d would like to keep it 38x18 and not worried about the depth. firing to the rear or up not sure yet thanks for the help Quote Link to comment Share on other sites More sharing options...
Socky Posted July 13, 2012 Report Share Posted July 13, 2012 sub up and port to the back. Quote Jeep Cherokee 4dr -4.75 in front, new rusty's 4.5 in rear leafs -micky thompson 35x14.50x15 -locker rear -Rusty's offroad Engine/transmission/transfer case/crossmember/gas tank skid plates -Warn front bumper with 8000lb winch -Custom rear bumper -Warrior product tube doors (summertime) -Optima redtop (starter) -26XK miles and still runs like a bat out of hell Kenwood H/U 1/0 wire, 136 amp alt 200 ah batteries 12.7 daily 2 Apsm 1500 @ 2 ohm strapped on zv3 d1 with ns softparts Mb quart 125.4 wired to 4 aura 6's 3.6 cube box tuned to 36 plays down to 23hz Link to comment Share on other sites More sharing options...
wilcox81 Posted July 13, 2012 Author Report Share Posted July 13, 2012 can go taller and deep if need be Quote Link to comment Share on other sites More sharing options...
Joe X Posted July 13, 2012 Report Share Posted July 13, 2012 Its seems kind of short but I still need to know the amp ans the subs exact models. Quote Link to comment Share on other sites More sharing options...
wilcox81 Posted July 14, 2012 Author Report Share Posted July 14, 2012 Audiobahn aw1500x 15s im going to be running 2 audiopipe 1500 watt amps. It has to be 38" wide have 30" deep and 24" high. this is a dd want it to be loud but play everything. Quote Link to comment Share on other sites More sharing options...
Joe X Posted July 14, 2012 Report Share Posted July 14, 2012 (edited) Here is a suggestion: Enclosure Specifications: Fb = 34 Hz Vb = 5.4 ft^3 External Height = 18 in External Width = 38 in External Depth = 23 in Port Width = 5 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: 2 x Top & Bottom (3 parts) = 38 x 23 Left & Right Sides = 21 1/2 x 15 3/4 2x Front = 16 1/2 x 15 3/4 Back = 38 x 15 3/4 Shared Port Internal Assembly Parts: 2 x Front to Back = 19 x 15 3/4 Assembly guide (generic dimensions): Edited July 16, 2012 by Joe X Quote Link to comment Share on other sites More sharing options...
wilcox81 Posted July 15, 2012 Author Report Share Posted July 15, 2012 That would mean the port will be firing towards my wheel well i would like to slot port the box Quote Link to comment Share on other sites More sharing options...
wilcox81 Posted July 15, 2012 Author Report Share Posted July 15, 2012 And thank you for the help Quote Link to comment Share on other sites More sharing options...
