Same dimensions, pair of 4" aeros, 23" long. leaves you a little bit more volume, which shouldn't be a problem unless you're overpowering them significantly.
Just say no to Ground Pounder Customs.
More box builds
some cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches!
I'm with captain stupid.
i believe i was once told that porting to the passenger side in my car is one of the ways to make it loudest. i think Orion Stang is the one who told me that. I want to do an aero port though.
You also need to set the number of common walls to 3 if keeping the slot port.
how 3?
What the f**k is an appropriate signature supposed to look like?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
Rockford Prime 200.2
Pioneer 6.75" Comp Set
XS S3400, D2700
Project DB Battery Terminals
Axxess ASWC
Stinger HPM Everywhereeee
90 Sq. Ft. of Stinger Roadkill
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/
My Old Build: http://www.stevemead..._+2000 +mustang
Avatar Courtesy of SnowDrifter
well....a single 12 at 2 ohms on saz-1500....not too overpowered.
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
don't worry about what it looks like on sketchup when you're using aeros haha. just mark the cutouts and make sure they don't hit anything.
More box builds
You should be fine with the same dimensions and a pair of 4" aeros.
Edited by 412 CVX
More box builds
thanks CVX, ill make a mock up of that and see how that turns out
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
One question, why would i do 2 4 inch aeros at 23" instead of 1 4" aero at 10"? I understand about the added port area, but what difference would that actually make irl?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
If you want to play it safe though, take an inch off your depth. it raises the tuning about 1.5 hz, but that shouldn't be very noticable.
More box builds
You can do that, but you'll notice a significant amount more output with a pair.
there's sort of a happy medium between too much area and too little area.
too much and you could run into unloading issues and possibly over excursion
too little and you're leaving a lot of output on the table.
More box builds
ive got a little extra cash, ill try out 2 of em just for shits and giggles and build the box hopefully tomorrow in my spare time....if i have any
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
  • Who's Online   0 Members, 0 Anonymous, 2193 Guests (See full list)
