ported box 10" sub
Hello SMD clan ...
I need some good input on purchasing a 10" sub
I have built a ported box for a single 10" sub tuned to 30hz
The box is 2.55 cuft but currently i am searching for sub that can play in a 2.55 cu ft
and sound great. At the moment i have 2 x 10" Alpine Type R's which i had in a sealed box
with only about .75 cuft per but could not stand the sound so i built the above box for a single sub (kept it simple).
I know the new version type R's that i have are not designed for a box this large as i can easily push the sub to the max excursion
and the voice coil starts to pop. Running a Rockford Power series T10001BD which i know is alot of power for that 10" but
I had this amp on an RE 18" in a 7 cuft box before this, sold the car so out came the box and sub, as i could not fit it in my Titan.
I have been looking at Image Dynamics / new Pro Series RE / FI BTL any others that someone could recommend
that will work in 2.55 cuft and sound great? Oh and not hit the max excursion at 1/3 volume !!
Thanks
Dc neo 10..just cause the magnet/motor is huge & will take up a lot of that room
1998 Pontiac grand prix gtp supercharged2 12" Obsidain Audio V.1 on a 2011 zx1500.1 at 2 ohms. 20ft of Knuconceptz CCA 0 Guage. 2nd Battery is a Shurken BT-120. Box is 3.5cu tuned at 31.8hz sealed off from the trunk. 14sqft of Dynamat on the Rear deck top & bottom. Soon to be more for doors/roof. Gets low & loud
Did a 140.5 Sealed at Battle of the boom in June 2013 dropping to 12.7v (need a alt mines going bad)
This is probably one of the only few 10's that doesn't mind a box that big
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=264-1108
Though if it was me, I'd just turn the box in a 12' box, and find a sub that doesn't mind 2.5 cu ft like the SSA Gcon or something
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
Omega has a good idea thats cheaper than mine
  • Who's Online   0 Members, 0 Anonymous, 1258 Guests (See full list)
