should i do 4th order or just make a ported box.....
for dimensions on torres box calc i came up with
18h by 24 w by 24d= 4.83 cubic feet
having trouble with port area...... dont know how much port i should need..... gunna be way underpowered for the time being til i can afford a new amp...... they will see about 300 rms and they are rated for 500 rms a piece per mtx
i want it tuned low cuz i like the low lows
specs of subs:
Free Air Resonance Fs 21.5 Hz
Volume Acoustic Suspension Vas 7.37 Ft^3 (208.8 l)
Total Q Qts .41
Electrical Q Qes .42
Mechanical Q Qms 9.62
DC Resistance Re 7.49 Ohm
Linear Excursion (One Way) Xmax .50” (12.7 mm)
Effective Piston Diameter D 13.000” (.3302 m)
RMS Power Handling RMS 500 Watts
Total Power Handling Total 1500 Watts
Sensitivity 1W/1m SPLo 89.0 dB
Reference Efficiency No 0.46%
Frequency Response 20 - 150Hz
Voice Coil Inductance Le 9.2 mH
Gap Height .375” (9.5 mm)
Voice Coil Height 1.250” (31.8 mm)
Motor Force BL 25.41 Tm
Compliance Cms .203 mm/N
Total Moving Mass Mms 271.0 g
Moving Mass of Driver Mmd 256.6 g
Suspension Losses Rms 3.80
Effective Surface Area Sd 132.7 in^2
Mounting Diameter 14”
Overall Diameter 15 5/8 ” (396.9 mm)
Mounting Depth 6 9/16” (166.7 mm)
Overall Depth 7 3/16” (182.6 mm)
Speaker Displacement (Inside Box) 352in^2 (5.8 l)
Speaker Displacement (Outside Box) 235in^2 (3.9 l)
suggestions? i have a ton of space in my wagon as the back seats fold flat so space really isnt an issue
Edited by 95legwagon
i think there real i was looking through that guys stuff he sells and it looks like he finds stuff at auctions and just sells it
Yea, it looks like someone got the mids about a month ago....shit. If I had a whole Hertz front stage my ears would jizz all over my cheeks.
/ LOL
My Low Budget Build:
Green 1995 Subaru Legacy wagon 147k- $1K
headunit- pioneer premier deh-p650-$25
4 Lead acid batts. 1 up front and 3 in back- vented outside.- $50
4 vvme L11 10"s <- $30 shipped a piece
6 cu. ft box (after displacment) tuned to 32ish hz with 10 inch sonotube. -about $50 all together maybe a lil more
2 aspm 1300 strapped
Selenium 6"s in the front doors on headunit power- for now -$20
quantum tweets in door-for now -$10
boston acoustic 5 1/4 in rear doors- for now-Free
big 3
1/0 and 4awg throughout.
roof sound deadened (not peel n seal ftw)-free
on 80 amp alt (bench tested to put out 100 amps faithfully) <--?-$10 for test
about $430 for everything<----Not bad at all
still gotta add 3 way crossover, amp for front and rear door speakers and maybe eq
i cant help you with a box, but i can tell you you're gonna need to spend some money for an amp that does 1000w at 4 ohms
????? you have a pair of mtx 7000 15? T7158 or t7154??????
I am a huge MTX fan of that circa and those woofers parameters no likey ported enclosures to much. I TRYED LOL.
Bandpass may be OK but, if you are willing to part with them let me know. LOL
http://archive.mtx.c...nderSub7158.cfm
Man don't make me go home and break out the brochure and spec sheet on these woofers. LOL
do it anyways lol jk
they are the 8 ohm version unfortunatly and yes i got a pair of these today from a buddy on a good trade.
and Kranny i was thinkn the same thing..... to get an amp thatll do an actual 1000 watts rms @ 4 ohms is definitly gunna take some cash.....
i dont really wanna sell but if you got another pair of 15's that are worth it for me i might think about gettin rid of them
/ LOL
big 3
ouch the t7158....I don't even know why offered this configuration as the amps that were available at the time could not come close at 8ohms. If they were the 4 ohm version each I'd more than take them off your hands. Let me know a price via pm if you end up going another route.
lol ok can do :)
/ LOL
big 3
ok so maybe a sealed box then lol..... but my question is..... can a sealed box be too big or small? like what if i wanted a 6 foot cubed sealed box? would it be louder?
/ LOL
big 3
