Joe X Posted July 18, 2012 Report Share Posted July 18, 2012 Ok one thing is that is not recommended to install an amp on an enclosure as vibration can damage the amp, also you have to decide if you want to go with a larger net volume and finally if you can provide the model of the vehicle this is going in. Quote Link to comment Share on other sites More sharing options...
ItsMoldyYo Posted July 18, 2012 Author Report Share Posted July 18, 2012 1999 chevy venture, Quote Link to comment Share on other sites More sharing options...
ItsMoldyYo Posted July 18, 2012 Author Report Share Posted July 18, 2012 Its getting a double baffle on the face of it and thick rubber under the amp legs to prevent any damage, I know its not good for the amps to be mounted on the enclosure.... And if you strongly recommened against it still any thoughts then... Quote Link to comment Share on other sites More sharing options...
ItsMoldyYo Posted July 18, 2012 Author Report Share Posted July 18, 2012 I was also going shallow and long like that to prevent sliding around in the vehicle or tipping over, as if that would be a problem with a 53 lb motor lol, my two tens in there box now slide to all beat hell in my 99 olds eighty eight, so I ratchet strapped to the trunk frame to the ports on both sides.... Quote Link to comment Share on other sites More sharing options...
Joe X Posted July 18, 2012 Report Share Posted July 18, 2012 (edited) Here is a suggestion for your venture: Enclosure Specifications: Fb = 36 Hz Vb = 1.25 ft^3 External Height = 11 in External Width = 37.75 in External Depth = 11.5 in Port Width = 2 1/4 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: 2 x Top & Bottom (3 parts) = 37 3/4 x 11 1/2 Left & Right Sides = Side 1 = 10 x 8 3/4 Side 2 = 10 3/4 x 8 3/4 Front = 34 3/4 x 8 3/4 Back = 37 3/4 x 8 3/4 L Port Internal Assembly Parts: Front to Back = 7 3/4 x 8 3/4 Extension = 16 1/4 x 8 3/4 Assembly guide (generic dimensions): I would like to see 2 12s there instead of this, is a worthy sub but that vehicle is huge. Anyways let me know of any modifications or questions you may have. Edited July 18, 2012 by Joe X Quote Link to comment Share on other sites More sharing options...
ItsMoldyYo Posted July 18, 2012 Author Report Share Posted July 18, 2012 That is a rather huge lookin box, I do appreciate it, and yes I would love to see 2 in there as well, at 440$ start for one its tough....kids put my dreams off week after week, its always something that takes daddys savings lol... If I can save up enough I might need a box design for two!!! But for now I think that will be the winner!!! Thanks joe for your help, ill see what I can do about a link for some pics of the other box you gave me the help on....looks pretty schnazzy, cutom fabric on it as well....thanks again joe!!!! Quote Link to comment Share on other sites More sharing options...
ItsMoldyYo Posted July 18, 2012 Author Report Share Posted July 18, 2012 Joe, let me know if you were able to see the box on this link.....http://www.facebook.com/media/set/?set=a.3455349378708.2131001.1120030323&type=3#!/photo.php?fbid=3632156478775&set=a.3455349378708.2131001.1120030323&type=3&theater Quote Link to comment Share on other sites More sharing options...
