yakofamily Posted July 20, 2012 Author Report Posted July 20, 2012 big diff gonna def swap the back out for those how about the front ? I used the standard motorcraft stockers up front. After the swap the front and back your basically the same height. I could carry 4 passengers (about 600 lbs) and 400+ in the trunk without bottoming out on bumps. A word of caution tho.. don't use the aftermarket plastic / metal strut tower mounting brackets. Use the rubber OEM motorcraft ones the aftermarket ones suck. Edit: also I had a 255/30r20 on there and still had clearance so you should be straight. sounds good thats what ill do ill put sum pics up wen i get the work done i see sum 20s in ma future if da ride gets better thanx for ya help brooklyn style
SojiaRaggs9000 Posted July 20, 2012 Report Posted July 20, 2012 No problem man if you need any help pm me. I had my 05 Taurus since 06 and did 90% of the work myself so Im an open book when it comes to them haha. Also alot of the other model taurus parts are swapable on theses cars. Motice the rear calipers and rotors on my old 05 (they dont offer a rotor for 2000-07 models) * Eclipse CD3200 with PAC SWI-CAN2 and SW-ECL2 Steering Wheel Controls Interface* Pioneer D-Series Mids and Highs ( Fronts: TS-D1702C; Rears; TS-D1702R and Dash; TS-D1002R )* Rockford Fosgate PBR300X4 ( Mids and Highs Amp )* DC 3.5k with Dual Inputs; Custom Plexiglass Backing ( Sub Amp )* Rockford Fosgate Balanced Line Driver * One FULLY LOADED ~ 10" DC m2 XL* Custom Built Carpeted Ported Box Tuned to 32hz. Single Chamber With Volume of 1.44618³ ft ; 1.13216³ ft After Displacement* Custom Built Carpeted Trunk Wall with Added Fans for Amplifier Cooling* MechMan 240a High Output Alternator * KnuKonceptz Krystal Kable RCA Cables* Upgraded Electrical With 1/0 KnuKonceptz Kolossus Fleks Kable and 1/0 Sky High Car Audio Cable* Five Exide Orbital ORB34M Marine 12 Volt Batteries* PowerMaster XS D3100 12 Volt Battery My 2008 Chrysler 300 Limited - SuperCharged 3.5L V6 - UBL My Old 2005 Ford Taurus - CarDomain - Vehicle Was Sold
