Migz Posted July 19, 2012 Report Share Posted July 19, 2012 Just wondering if this would help much? I've only got a 70amp alt at the momment, and I've got 4 gauge with some 80 amp fuses, and the wire can easily take that. So would it help at all if I did the big 3 but in 4 gauge and not 0? Link to comment Share on other sites More sharing options...
LZTYBRN Posted July 19, 2012 Report Share Posted July 19, 2012 As long as it's bigger than the factory wire it'll help. Link to comment Share on other sites More sharing options...
Bump4life Posted July 19, 2012 Report Share Posted July 19, 2012 how much power you running? you alt line will be fine being 4 gauge until you get a H/O alt. your grounds, the bigger the better. you will notice a difference in voltage by going to 0 gauge grounds, how much? idk i saw a .8 volt increase going from 4 gauge to 0 gauge OFC grounds. went from 13.3 to 14.1. if you are running under 1k 4 gauge will be fine for all of big 3 Buyer/Seller Feedback Thread: http://www.stevemead...5015-bump4life/ MB C220 153 Trunk Car Build Log: http://www.stevemead...d/#entry1840136 MB C280 Ipad Dash SQ Build Log: http://www.stevemeadedesigns.com/board/topic/194484-bump4lifes-new-benz-tony-c-relay-kit-pictures-ce-electric-audison-front-stage-installed/ My SPL Log: http://www.stevemead...__fromsearch__1 BMW M340 xDrive Stock, for now. Corner Load 10" maybe soon. But does 10s in the 1/4... Best Scores out of a trunk 153.0 sealed legal full tilt clamped 5524 @ 42 hz 154+ windows down, 155+ kick Link to comment Share on other sites More sharing options...
Migz Posted July 19, 2012 Author Report Share Posted July 19, 2012 Running about 1200. But really can't afford anymore 0 gauge just yet. And I've got all this 4 awg left over. May just do two runs of 4 awg on alt + to bat. Just noticed I posted this in the wrong section, sorry. Link to comment Share on other sites More sharing options...
Bump4life Posted July 19, 2012 Report Share Posted July 19, 2012 4 gauge will be better then stock most likely. adding wire never hurts Buyer/Seller Feedback Thread: http://www.stevemead...5015-bump4life/ MB C220 153 Trunk Car Build Log: http://www.stevemead...d/#entry1840136 MB C280 Ipad Dash SQ Build Log: http://www.stevemeadedesigns.com/board/topic/194484-bump4lifes-new-benz-tony-c-relay-kit-pictures-ce-electric-audison-front-stage-installed/ My SPL Log: http://www.stevemead...__fromsearch__1 BMW M340 xDrive Stock, for now. Corner Load 10" maybe soon. But does 10s in the 1/4... Best Scores out of a trunk 153.0 sealed legal full tilt clamped 5524 @ 42 hz 154+ windows down, 155+ kick Link to comment Share on other sites More sharing options...
CleanSierra Posted July 19, 2012 Report Share Posted July 19, 2012 As long as its OFC, it will carry the current. Max draw on an amp that pushes 1200 watts at 80% efficiency(which is being generous, its likely lower), and battery voltage of 14.4V, puts you at an amperage draw of 104 amps at full tilt. KNU Konceptz 4 gauge will allow 100A, so you'd probably be fine. I realize I'm talking about your POWER wire run, but even in your Big 3, you'd be ok with running I think. Im not the one you want to try to troll. Just a fyi for you. Link to comment Share on other sites More sharing options...
