SnowDrifter Posted July 20, 2012 Report Share Posted July 20, 2012 I was thinking about when setting high pass/infrasonic and low pass crossovers.. As I understand it: When setting a high pass/infrasonic, the crossover knob is turned all the way down, the unit is set, then slowly turned up until the unit registers a -3db change in the output voltage of the source(amp, external crossover, etc) Then when setting a low pass, the crossover knob is turned all the way up, the unit is set, then slowly turned down until the unit registers a -3db change in the output voltage of the source. My question: Since the respective crossover knobs have to be turned opposite directions after pressing 'read' on the cc-1 to set them, how can the up and down arrows on the unit be pertinent for each? Note: I am not bashing or criticizing the product in any way. I am just asking a question that has been on my mind since I don't have a cc-1 in front of me to play with and answer my own question Quote ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
SnowDrifter Posted August 16, 2012 Author Report Share Posted August 16, 2012 Quote ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
Jessica Posted August 18, 2012 Report Share Posted August 18, 2012 I believe It's opposite for the infrasonic, up is down and down is up. I don't own one, but test it out. If the down arrow is right when setting the lpf, then setting Hpf's it will be opposite. Quote Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13 Link to comment Share on other sites More sharing options...
SnowDrifter Posted August 19, 2012 Author Report Share Posted August 19, 2012 Yeah, but I didn't see the manual mention that. Although I may have missed it. /confusedface Quote ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444 Link to comment Share on other sites More sharing options...
