My stock belt is 60.5" long and .82 in wide, 6 rib.
I need to find a belt that is 1"-2" shorter, but had no luck so far.
I ordered one from vbeltco.com but it turned out to be too wide.
Could you please help me find one or tell a place where I can order one.
Thanks
what car? go to napa look in there gates belt book and find length...they do not go in order or size increments..meaning it would be nice if they went in 1/2 in increments but they dont some jump a inch etc..you could always put a smaller idler pulley also,,to gain the inch or so
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
like i said in back of there belt books are the sizes then you just get the numbers..i have 5 diferrent sizes an multiple pulleys all to try and get rid of belt slip on my 3 alt setup..gates has website also
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
Yep- I had to do this at Autozone. I took in my existing belt and told them I need one shorter. Hopefully you can find someone behind the desk that is helpful. The guy who helped me had to make several trips back and forth, but they found one that was spot on. Just compare it to the one you have and put them side by side until you find the right one.
IMO, that would be easiest for you too.
12 - 12"s in the STAY PUFT 1989 Chevy Astro
Build & Comment Log
Un-Interrupted Build Log
YouTube Channel
Chevy Trailblazer 5.1 Dolby Digital DTS Install
You have a beard of a mysterious sea captain. I would follow you to hell and back.
I already tried advanced auto parts, and the guy said the shortest they had was 56". I needed 59.5-58.5.
I didnt read replys. I was told by Tom @ ohio gen the smaller belt is always the next part number down.
2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable
(2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <-------
Needs more power those woofers will laugh at that turd
They actually do go up in size increments. Usually half inch. I work at autozone. The should be able to figure it out. I was taught this when I started.
1999 GMC Yukon, 6 PSI platform 5 18's, 4th order bandpass by BHE, Taramps,
  • Who's Online   0 Members, 0 Anonymous, 2712 Guests (See full list)
