Hey guys I am wondering what size fuse to run through my system. Right now i have a 100 amp alternator i will upgrade to a 200 down the road sometime. also i will have a XS D3400 under the hood too very soon. and the amp will be a DC 3.5k
I am wondering what size fuse do i use from the alternator to the battery and then the battery to the amp? all wire is zero gauge and big 3.
Thanks for the help.
2001 GMC Sierra DC Audio Build =http://www.stevemead...o-level-4-build
2001 GMC Sierra
XSPower D3400
Pioneer AVHD 1400
​MB Quart Component Sets
Pioneer 5x4s
Audiotechnix Power Wire, Speaker Wire, Sound Deadener
DC Audio Level 4 10s
DC Audio 3.5k
Rocford Fosgate R400-4
HID 6k
Slammed Truck on 20s
Candy Blue.
Hello bud.... This advise is given under the assumption that you are running good wire, and not some mickey mouse crap. Keep in mind, not all 1/0 is created equal...
With that being said, your 1/0 wire can carry up to 300 amps of current. So for one, definately do not use a fuse with any higher than a 300A rating. Between your alternator and battery, keep it between 300A and the max output of your alternator.
The amp you are getting calls for a 300A fuse, and accepts 1/0 power and ground. SO I would go with a 300A fuse there.
DC also makes some othert reccommendations that you can find here: http://www.dcsoundlab.com/35k.html
I am using new audio technixs power wire zero gauge and it is working great. thank you very much
2001 GMC Sierra
XSPower D3400
Pioneer AVHD 1400
Pioneer 5x4s
DC Audio 3.5k
HID 6k
Candy Blue.
x2
2001 vw gti
2 hds212s
4.75 net tuned to 34hz
audioque1200 wired to 1 ohm
nvx 0 gauge to the back
kinetic khc 2000
kenwood deck
  • Who's Online   0 Members, 0 Anonymous, 2712 Guests (See full list)
