boomin' brick 93' Volvo 240 build (4) 10's - Update: 6-20-14 EQ Install w/Build Pics
Damn dude!! Clean work! Brick society right here too! :D glad to see someone doing a build on a clean 240! Too bad it isnt turbo or you coulda gone a different route ;) lol. And damn, a 93 with 90k on it?! Its still in his pre teen days :P
2007 Volvo S40 2.4i (no turbo :( )(Soon XS Power D2400) Stock battery for nowRockford Fosgate 4 gaugeAudioque 6.5" Mid Bass (front)Rockford Fosgate T1 Tweets (front)Rockford Fosgate T2 6.5" Mids (rear)Rockford Fosgats T600-4 (Mids and highs)Rockford Fosgate P3001Fi SSD 12" with PSI recone, building box<p>400 watts, 139.3 @ 42 hz , in the kick window open. Build log!!http://www.stevemeadedesigns.com/board/topic/159148-2007-volvo-s40-audio-build-start-to-current-comment/
Thank a lot man. Hopefully I'll get back to work on her soon.
nice to see another member from rhode island, nice build man. looking forward to updates.
Thanks alaskanzx5 I might just do that
I can recone a sub myself. About a year ago I took 2 12" power acoustic mofos and made one sub. I took the magnet and the motor off of one and j b welded it to the other motor and magnet. I had to wind my own voice coil so it would work. After I was done hooked up to 2 boss 5000w amps. And shattered my back and all my side windows
came to this thread to recommend soundqubed and ct sounds. OP goes with soundstream.
oh lawd.
Yeah the good ole ocean state hahaha thanks a lot man
  • 10 months later...
  • 4 weeks later...
It's been a while since i posted any progress so here's the latest
I decided I wanted an in-dash EQ so here's what I did to mount it
first was some tape
then I used some pieces of wood to layout where I wanted the EQ to be positioned and used a little CA glue to hold it in place
Then I layered some fiberglass mat over it
I used the EQ as a mold for a tray that would hold it securely
While that was drying I layered some more fiberglass mat on the inside of the panel
Using some more fiberglass mat I attached the tray to the front trim piece
Those two piece of tape are covering the threads of two bolts that connect the front piece to the inside piece. This whole panel is held in without any modification to the factory dash
I used some epoxy to hold the bolts from spinning
The front piece after some duraglass
Both piece's primed and the front is ready for paint
first some texture coating
and the finished product after paint
here it is installed
it was a fun little project and i'm happy with the results
Thanks for looking :)
  • 7 months later...
Hello dude, fine work on the ride.
Is there any possibles you could make some pods with 6.5inch in front doors and ship them?
i will pay for job if you find this fancy.
working on the same car(S) for some time and yours is clean and nice i would say :)
Volvo 240 estatewagon daily used 1991 classic.
Volvo 240 1979 non orginial turbo xO xO
