Sub Box for SAv2
Hi,
I just became a proud owner of a Sundown Audio v2 8". Ive been doing some research and found out that the sub only needs .75 cu ft of space. What is the size of the port going to be for this sub. Also the dimensions of the box would be needed. Sorry for being a noob at box building.
Thanks.
2010 GMC Sierra SLE Texas Edition Sky High 2/0 OFC Wiring
2 Digital Designs 1508's Supercharged
Digital Designs Door Speakers
Rockford Fosgate T1500-1bdcp
Rockford Fosgate Prime 300x4
Rockford Fosgate 3Sixty.3
SMD VM-1
XS Power D3400
Unless you running 400rms or under build it in 0.6cuft
My recommendation is
10h
Port 8.5x1.25 (could do 8.5x 1.125 if you need the space)
Tune it to 32-33flat and no higher unless you aftet more spl
What do you want to achieve with it?
And how much power?
I'm putting it in a 2005 ford f150 crew cab. Since the seats sit so low I decided just to put it in the center seat of the back seat with the sub facing forward.
SMD VM-1
XS Power D3400
I'm going to have it powered by a Crossfire C3 501. 500 watts rms on a 1 ohm load
SMD VM-1
XS Power D3400
You should get it under the back seat if not even behind it,
Do you have the amp already? if not idd recomend a bit more power if you can closer to 600-800 rms
I take it you have the dual 2ohm
And meserments?
You have any
Edited by john253a
And meserments?
You have any
This guy knows a thing or two about designing enclosures. you can't go wrong with his recommendations!
Good luck
Edited by VaNQuisH
Currently:
* Hybrid Audio Legathia 3-Way Active Front Stage
* (2) Morel Ultimo 12's
* (2) Arc Audio 1100.1 XDi v2 (Strapped @1ohm)
* (1) Arc Audio 1200.6
* RF 360.3 DSP
I will have to give you the measurements when I get the truck back tomorrow as it is in the shop. It is nearly impossible though to have the sub sit underneath the seat and the seats can't fold since they are bolted to the back of the truck so behind the seats is out of the question.
SMD VM-1
XS Power D3400
Hows your 8 going
Really shines once it broke in. Enjoying it very much (not to mention the extra trunk space lol)
Edited by VaNQuisH
Currently:
* RF 360.3 DSP
  • Who's Online   0 Members, 0 Anonymous, 2370 Guests (See full list)
