Bass Box Pro 6...Just got it, help me understand it a bit
Ernesto
i made a mistake
look here
your port length should be 5.714 for 35hz
QL = air los from leaks,  how your suppose to know this I have no Idea, I'm no Expert with this proggie, I make  it work for me thou, its trail and error, also the help guide is AWESOME
i made a mistake
look here
What do you put for QL? 0 ?
  • 5 years later...
  • 6 years later...
click on bass box pro
icon then click on design wizard
click on start with diver then click next
then click search driver database then click next
under company search for the name of your drive Rockford Skar ext
then click on drivers found tab
click your diver model than from there click on the blue load button on the bottom right corner
from there another box comes up there you will choose how many subs you are working with if it will be isobaric push-pull  and wired in series or parallel
from there then click the green accept button
another box will come up asking you to click next do so
next it will ask you what type of box you want to build read what it says before click next because its important to the type of box you'll be building after reading click next
next will be another box where it gives you the option of choosing the type of box you want to choose what you want to work with than click next
yet another box will pop up
in this box is where you ad your dimension
the tabs at top also give you options as well if you want to add polyfill under damping or not vent is where you figure your port out the interior tap is where you decide whether you want front mount rear mount or flush your sub
after your done with all that click the green button accept
another box pops up click next
now another box pops up this is to analyze your box design
once you have click the blue button finish
now you should be at the window where you have a bar graph of your band with click the box tab that will take you back to the box design click on parts list that will give you your cut sheet modify as needed
  • Who's Online   0 Members, 0 Anonymous, 479 Guests (See full list)
