Battery Is Going Dead
Not completely dead. But my Car is sluggish starting up. My battery terminal also tells me its "Lo". When the car starts up the voltage jumps back to the 13.8 its usually at. But when I turn the car off it slowly drains to around 10.1 volts and then says "lo". Here is my battery:
So I now need a new battery that is about the same or better. Maybe powermaster? Also Do they have the same stock mounting groves in the bottom?
Btw: this is the only Battery in the Jeep for now. I know I will need more.
Any ideas on a Battery that would be equal to or better than this one? Or should I just get one that will fit in its place (size)? Im looking at Kinetiks and powermaster. thanks
are you sure its ur battery and not alt
a kinetik 1400 would replace nicely
or
powermaster d1200
both will have more available power
or
powermaster d1200
Thanks thats what I was looking for. I dont know much about Batteries. If it is my alt it really doesnt matter, because in acouple of days I should have my 300a Alt in :)
But it wouldnt be the alt if the voltage is fine while the car is on....it drains real quick when the car turns off. Or is that a sign of a bad alt?
Alright thanks alot. I just didnt want to get a battery that was lower quality than the one I have. So Ill look at those or the next level up. Thanks again.
  • Who's Online   0 Members, 0 Anonymous, 3902 Guests (See full list)
