good amp for VVX 10s
Papaslim
I have 4 vvx 10s and would like some suggestions on a good amp for them that's under $350.
Getting loud is only half the job;sounding good while doing it is where the glory is.1998 Jeep CherokeeHead Unit: Pioneer AVH-P6300BTFront Stage: Kenwood 6.5Rear Stage: kenwood 6.5Tweeters: SoundstreamMids/Highs amp: Hifonics Zeus 600.4Sub Amp: Hifonics BRZ2400Subs: 4 Skar VVX 10s(only running 2 now; still has all of them though)Batteries: Optima Red Top(under the hood)XS Power D1200(in the trunk)0 AWG Power Wire
2003 Kia Sorento
Team Subsonic Lows
Team Bassin' on a Budget
I have everything in my sig and I am looking into getting a HO alt pretty soon. Will that be good enough for now?
Are they dual 2 ohm, i'd assume your looking for a 1 ohm load right.
If so then that brz 2400.1 is prb your best bet for under 350, just make sure you scope it right or use a dd1 and you'll push those vvxs just fine.
My current 95 Jetta Build w/
pioneer h/u
2 RD Sonance 10's with flatwind coils
2 Audiopipe apsm 1500.1s
1 Hifonics Brutus Elite 60x4
1 XS d925
1 Stinger spv35
1 1000 amp lead acid
50 ft of 0/1 ofc from Audiotechnix
all powerbass components, and coaxils, 4 sets
buildlog = http://www.stevemead...2-rd-10s-build/
My build for my wife. http://www.stevemead...01-f-150-build/
With an HO alt, you should be set to run either.
2003 Kia Sorento
Team Subsonic Lows
Yes they are dual 2s
It will be about 2 to 4 months before I can the the H/O but I don't use my subs every; they may be used twice a month or so. So, will the Shuriken and the red suffice until then? I will also do the be three at the end of August.
you'll be fine w/o the alt as long as you keep an eye on your voltage and don't let it drop to low. you won't be getting full output but you'll be thumping till you get your alt
pioneer h/u
1 XS d925
1 Stinger spv35
  • Who's Online   0 Members, 0 Anonymous, 1008 Guests (See full list)
