SlamminBeats Posted July 30, 2012 Report Share Posted July 30, 2012 Im asking for a comparison of entry to medium level subs, off the same power, in the same setup. nobody can tell you. what if the next step up needs more power to get going, could be less loud. that question was much easier to understand too. Link to comment Share on other sites More sharing options...
AmmoJammo Posted July 30, 2012 Author Report Share Posted July 30, 2012 146.6 db at 40Hz, 1500 watt amp, db drag street stock, sealed on the dash, two pioneer ts-w307d2 Link to comment Share on other sites More sharing options...
SlamminBeats Posted July 30, 2012 Report Share Posted July 30, 2012 hmmmm maybe, just dont know why a person doing a 146 would ask this question Link to comment Share on other sites More sharing options...
AmmoJammo Posted July 30, 2012 Author Report Share Posted July 30, 2012 As i said, looking for a comparison of subs. No point spending $1500 on subs only to need more power to do the same numbers. Link to comment Share on other sites More sharing options...
AmmoJammo Posted July 30, 2012 Author Report Share Posted July 30, 2012 im thoroughly convinced you did not do a 146.6 with 2 entry level subs on 1.2k...no not sealed not on the TL. =/ are you Terry Brocks? Link to comment Share on other sites More sharing options...
Jman08 Posted July 30, 2012 Report Share Posted July 30, 2012 didnt realize ya had a wagon but props if that was sealed on the dash Youtube.com/J Hutch22 Link to comment Share on other sites More sharing options...
Bump4life Posted July 30, 2012 Report Share Posted July 30, 2012 im thoroughly convinced you did not do a 146.6 with 2 entry level subs on 1.2k...no not sealed not on the TL. =/ are you Terry Brocks? just out of curiosity, which amp was it. i read your build log and it showed you using a DD Z1 which certainly isnt a 1500 rms amp ahah Buyer/Seller Feedback Thread: http://www.stevemead...5015-bump4life/ MB C220 153 Trunk Car Build Log: http://www.stevemead...d/#entry1840136 MB C280 Ipad Dash SQ Build Log: http://www.stevemeadedesigns.com/board/topic/194484-bump4lifes-new-benz-tony-c-relay-kit-pictures-ce-electric-audison-front-stage-installed/ My SPL Log: http://www.stevemead...__fromsearch__1 BMW M340 xDrive Stock, for now. Corner Load 10" maybe soon. But does 10s in the 1/4... Best Scores out of a trunk 153.0 sealed legal full tilt clamped 5524 @ 42 hz 154+ windows down, 155+ kick Link to comment Share on other sites More sharing options...
AmmoJammo Posted July 30, 2012 Author Report Share Posted July 30, 2012 Z1 was what I'd used on the two Elevation Audio subs, the Pioneers were being run off a ReSponse brand 1500watt. Link to comment Share on other sites More sharing options...
Bump4life Posted July 30, 2012 Report Share Posted July 30, 2012 Z1 was what I'd used on the two Elevation Audio subs, the Pioneers were being run off a ReSponse brand 1500watt. ahhh well very good!! just to answer your question, most likely if you get a beefier sub on same power youd prolly be quieter because speaker wont displace as much air as the lower models which will be more efficient on less power than your big ones. Buyer/Seller Feedback Thread: http://www.stevemead...5015-bump4life/ MB C220 153 Trunk Car Build Log: http://www.stevemead...d/#entry1840136 MB C280 Ipad Dash SQ Build Log: http://www.stevemeadedesigns.com/board/topic/194484-bump4lifes-new-benz-tony-c-relay-kit-pictures-ce-electric-audison-front-stage-installed/ My SPL Log: http://www.stevemead...__fromsearch__1 BMW M340 xDrive Stock, for now. Corner Load 10" maybe soon. But does 10s in the 1/4... Best Scores out of a trunk 153.0 sealed legal full tilt clamped 5524 @ 42 hz 154+ windows down, 155+ kick Link to comment Share on other sites More sharing options...
AmmoJammo Posted July 30, 2012 Author Report Share Posted July 30, 2012 The current setup I have, the Pioneers are getting about 800watts each, rated at 400. They'd have to be suffering pretty badly from power compression, which is why I'm hoping a higher powered, higher excursion woofer could still do similar numbers, off the same power. Link to comment Share on other sites More sharing options...
