same thing happened on my buddy's amp. we took the cover off and actually removed the RCA connect. took it out somehow (he did it) and put it back in. resoldered connections
did that work out good?
He got it out. It make it easier to work with for sure. I'll ask him how he got it out though. My only dealing in it was taking out the RCA female
here's what he did... so the core of the RCA stuck in there is plastic. heat up a pin and shove it in there at an angle so that it melts the plastic core then let cool. then pull it out.
you will have to resolder the RCA female unless you don't remove it from the amp
i would say to use the same rca wire that it broke out of then put some silicon or some kinda glue on the inside where the pin goes on the wire then push it back into the rca input.. but be careful not to get any glue on the terminal.. then let it dry and pull that bitch back out! when this happened to me i used some pliers.. nd then it happened again and i used the wire and got it out.. then switched to new wires
2008 BMW 550i M Sport
Build coming soon!
2000 Volvo s40 1.9T
Pioneer DVD navigation head unit
O2 audio performance mid range speakers
2 Crescendo PWX-6 Pro Mid Range Speakers
2 Crescendo PWX-8 Pro Mid Range Speakers
4 Selenium ST200 Super Tweeters
Hifonics ZRX2000.4 Amplifier
2- 12 inch DC Audio Level 4 m2
Hifonics Brutus BXI-1610D Amplifier
2 KinetiK HC1400R- Secondary Batteries
Kinetik HC600- Secondary Battery
Knukonceptz 1/0 gauge big 3 upgrade
I tried some glue but I'm scared to use too much. I tried a tiny tiny tiny screw and so far this thing is tighter than a virgin and not wanting to come out.
***2001 GMC 2500HD Regular Cab***
-Jensen 9312 Flip-Out
-2 12 inch Pioneer Step-up Shallow Mounts
-Kicker ZX750.1 for Lows
-Pioneer 6.5 coax in the doors
-Pioneer 4x6 coax in the pillars
-Old School Alpine MRV-F250 for Mids/Highs
***1969 Camaro Z/28***
-500+ cubic inch 950hp BBC + 400-650 shot of Nitrous
-Audio coming soon-
Good news!!! For this particular amp, there is holes in the top (Fosgate 25 to life power 1000), and I was able to.....................
Before
Hmmmm a hole.........
Maybe just pry on this here a little........
HELL YEAH!! After
-Audio coming soon-
Not too bad at all, it wasnt sealed off from the back so it made for a quick pry with a bent up key-ring LOL.
-Audio coming soon-
  • Who's Online   0 Members, 0 Anonymous, 670 Guests (See full list)
