davinci701 Posted August 2, 2012 Author Report Posted August 2, 2012 Well I was thinking about opening the amp up following the remote see if its burnt some where wonder if a little solder will do the trick but thanks everyone beeen trying all troubleshoots thanks tho Quote
davinci701 Posted August 3, 2012 Author Report Posted August 3, 2012 Ok just tried it out again turned up about half way and the amp made a REALLY loud tone even when I turned it all the way down on the stereo it was still loud soooo FREID or Not???? Please somebody help I'm feenin for bass haha Quote
RCP Audio Posted August 3, 2012 Report Posted August 3, 2012 Check every single connection, sounds like something is shorting to me. when i say check the connections i also mean make sure that they are safe the entire way from one end to the other. make sure the rca's havent split and are shorting out on the body for example. also videos help us alot determine the problem. but I wouldnt use the amp until you figure out what is going on as you don't want a BBQ in your car! Quote PSN: Rcp_soundz Good rule of thump is go by what fuse size is being used in these amps. The higher the more amperage it pulls, this is what I look at. I'll stick a 300 amp fuse in a potato and sell it to you for $2k. 1991 Mazda 323VERY small build thread here: http://www.stevemead...23-small-build/
