TwinkeyMerchant Posted August 2, 2012 Report Posted August 2, 2012 Ok, so i've helped a couple of my friends install system in there vehicles and my buddy who DJ's wanted me to build him a set up. He currently uses a Bass cabinet he use to use when he played bass with 4 10's in it... thing gets down but really just not enough mids and highs and one of the 10's is blown. Im really wanting to help him have a BADASS set up cause house partys with him there is just awesome. Anyways my main problem is how to power the subs and speakers. never did or looked up anything to do with home audio or anything like that so im kinda lost on the situation. If anyone would help shine a little light on whats good equipment to use to power his setup or send links to stuff that would work, I'd appreciate it. Btw, (being a basshead) i want him to be boooooming so i went with 2 15's for the lows, and need about 400w per sub... Quote
iceman1575 Posted August 3, 2012 Report Posted August 3, 2012 Budget? Crowd size? Type of music? Quote POTATO!
RCP Audio Posted August 3, 2012 Report Posted August 3, 2012 when you say build, do you mean physicly buy wood and drivers and make him a pa? or put together a list of stuff? i dont know much about making my own pa cabnets. but both iceman and myself will help you out hah. 80% of the live sound posts on here are from me and him haha Quote PSN: Rcp_soundz Good rule of thump is go by what fuse size is being used in these amps. The higher the more amperage it pulls, this is what I look at. I'll stick a 300 amp fuse in a potato and sell it to you for $2k. 1991 Mazda 323VERY small build thread here: http://www.stevemead...23-small-build/
Bump4life Posted August 3, 2012 Report Posted August 3, 2012 crown amps for pa audio. there are other good ones, and better ones but for the money you get quality product. if you run 2 quality 15s a 18 inch sub and 2 powerful super tweets it would probably be enough for a large room 300 people or so. Quote Buyer/Seller Feedback Thread: http://www.stevemead...5015-bump4life/ MB C220 153 Trunk Car Build Log: http://www.stevemead...d/#entry1840136 MB C280 Ipad Dash SQ Build Log: http://www.stevemeadedesigns.com/board/topic/194484-bump4lifes-new-benz-tony-c-relay-kit-pictures-ce-electric-audison-front-stage-installed/ My SPL Log: http://www.stevemead...__fromsearch__1 BMW M340 xDrive Stock, for now. Corner Load 10" maybe soon. But does 10s in the 1/4... Best Scores out of a trunk 153.0 sealed legal full tilt clamped 5524 @ 42 hz 154+ windows down, 155+ kick
RCP Audio Posted August 3, 2012 Report Posted August 3, 2012 crown ftw. or qsc. Dont do super tweets. Get a horn loaded compression driver. they spread the highs alot better then tweeters and are alot more effecent. How big is he wanting to go. I would suggest 2 cabs a side. one with a single 18. one with 2 15"s and a horn. You could do double 18's for subs if you want. depends how easy you want this to be moved around Quote PSN: Rcp_soundz Good rule of thump is go by what fuse size is being used in these amps. The higher the more amperage it pulls, this is what I look at. I'll stick a 300 amp fuse in a potato and sell it to you for $2k. 1991 Mazda 323VERY small build thread here: http://www.stevemead...23-small-build/
Alan Follette Posted August 3, 2012 Report Posted August 3, 2012 qsc is great on a budget. used to run 3 of the 1450s when I did live sound. as for speakers I built my own pair of 2x18 cabs with the eminence sigma pro 18s. We crossed those over at around 50-60 hz and MAN did they pound! Quote
Alan Follette Posted August 3, 2012 Report Posted August 3, 2012 This was my old live sound setup. 2 cabs with two 18s a piece and then 2 cabs with a single 15 and a tweeter. we used a cheaper Behringer crossover that worked ok but i linked to one that has time alignment and Auto EQ both things I really wish we would have had. I ran this setup for 2-3 years and did 2 shows a month in front of 400-600 kids it kept up amazingly well, easily overpowered the bands and maintained great SQ. However we only occasionally played bass heavy music but I would be confident this would work VERY WELL for 300-500 people playing rap/dubstep. Your buddy could probably get away with just two 18s at first if he doesn't have the funds for the full setup right off the bat. 18s 4x http://www.parts-express.com/pe/showdetl.cfm?Partnumber=290-427&FTR=sigma%2018 15s 2x http://www.parts-express.com/pe/showdetl.cfm?Partnumber=290-418 tweeters 2x http://www.parts-express.com/pe/showdetl.cfm?Partnumber=290-446 Wave Guide 2x http://www.parts-express.com/pe/showdetl.cfm?Partnumber=270-318 Sub Amps 2x http://www.musiciansfriend.com/pro-audio/qsc-rmx-2450-power-amp?src=3WWRWXGP Mid Amp http://www.musiciansfriend.com/pro-audio/qsc-rmx-1450-power-amp?src=3WWRWXGP Tweeter Amp http://www.musiciansfriend.com/pro-audio/qsc-rmx-850-power-amp Crossover http://www.musiciansfriend.com/pro-audio/behringer-ultra-drive-pro-dcx2496-crossover Quote
RCP Audio Posted August 3, 2012 Report Posted August 3, 2012 That's some good stuff listed there and a great place to start. Have a look through and see what you think would work for what he needs. And again this is personal preference I would use a horn over a tweeter anyday. But read up as much as you can on every item and make sure they will all work well together regarding crossover points etc. is he wanting the mid/highs to be bi amped? Another thing you can look into Quote PSN: Rcp_soundz Good rule of thump is go by what fuse size is being used in these amps. The higher the more amperage it pulls, this is what I look at. I'll stick a 300 amp fuse in a potato and sell it to you for $2k. 1991 Mazda 323VERY small build thread here: http://www.stevemead...23-small-build/
iceman1575 Posted August 4, 2012 Report Posted August 4, 2012 If you're wanting simple and quick, I highly recommend going the powered route. If budget is tight, then look at the likes of Behringer, Gemini RS/GVX, etc. Mid-priced range would be EV ELX (my personal recommendation), JBL PRX, QSC K/KW, etc. But the big name in the mobile DJ world is RCF. Brian Redd (Youtube DJ) uses them on his "one-man" setup (He had a stroke sometime last year and has limited mobility in his right arm) and he loves the 8" speakers, and have heard nothing but good things about them, if you can afford them. Again, it all comes down to budget. Quote POTATO!
RCP Audio Posted August 4, 2012 Report Posted August 4, 2012 The active mackies take a pounding aswel! and get dam loud! qsc and jbl are very music (concerts) bins IMO, the likes of the RCF's and mackies seem to me if they are more targeted to DJ set ups. The EV stuff is amazing gear and id place it right in the middle, good bang for you buck for sure Quote PSN: Rcp_soundz Good rule of thump is go by what fuse size is being used in these amps. The higher the more amperage it pulls, this is what I look at. I'll stick a 300 amp fuse in a potato and sell it to you for $2k. 1991 Mazda 323VERY small build thread here: http://www.stevemead...23-small-build/
