I currently have one Leadtek WinFast GTX560 Ti GDDR5.
Im looking for a solid card that can run 3 monitors, gaming on high at the lowest. I pay FPS. not Diablo 3 or anything.
I could get another 560Ti for 343.85, my current once can play anything on very high. Would two of these be enough?
or should i go for a single card and sell my current 560? give me some ideas
(prices are NZD)
PSN: Rcp_soundz
Good rule of thump is go by what fuse size is being used in these amps. The higher the more amperage it pulls, this is what I look at.
I'll stick a 300 amp fuse in a potato and sell it to you for $2k.
1991 Mazda 323VERY small build thread here: http://www.stevemead...23-small-build/
http://www.pbtech.co.nz/index.php?z=p&p=MBDGBM3032&name=Gigabyte-GA-970A-D3-AMD-970-SB950-ATX-Socket-AM3+-
that is the motherboard i currently have, not looking to upgrade that if i dont have to. but if it would help me run two cards then i could be convinced to do so
PSN: Rcp_soundz
Im doing some reading, and i dont think my motherboard would take 2 cards, as it only has one PCI x16 slot. Should i get a larger single card, or another motherboard. larger expansion might be in the near future, so a larger motherboard wouldnt be a bad thing would it?
http://www.pbtech.co.nz/index.php?z=p&p=MBDGBM7903&name=Gigabyte-GA-X79-UD3-Intel-X79-Chipset-Socket-2011-
I currently have an AMD FX-4170 processor
PSN: Rcp_soundz
PSN: Rcp_soundz
You have 2 PCI-E slots.
Get a second 50$ card and throw it in the other one to run your 3rd monitor. No reason to spend a bunch of money.
If you want to stick with nvidia, get something like a 9600gs, you could even use it as a physix card when you're gaming.
This is tough because you're in New Zealand. Components are a little harder to find over there and I don't even know where to look online besides the website you posted.
For your scenario I'd suggest upgrading your single video card rather than running 2 cards in SLI. The reason for this is that you'll not only need to buy the second 560Ti but you'll also need to upgrade your power supply to a 700W+ model in order to power both cards and the rest of the system. A quality 700W+ model on the website you posted costs around $194. Add that to the $343 for the 560Ti and you're looking at a total upgrade cost of around $537.
For $515 you could get a Radeon 7870 2GB and an adapter for a 3rd monitor: http://www.pbtech.co.nz/index.php?z=p&p=VGASAP7870&name=Sapphire-HD7870-GHZ-EDITION-2G-GDDR5-PCI-E-Video-c
Adapter: http://www.pbtech.co.nz/index.php?z=p&p=ADPSAP0005&name=Sapphire-ACTIVE-MINI-Display-PORT-(Male)-to-Single
The 7870 has a few advantages. It'll be a single card, meaning less power consumption (no need to upgrade power supply) and less heat (fans will make less noise). It also has 2GB of video memory as compared to the 1GB the 560Ti has. In a triple-1080p setup you'll want more than 1GB of RAM in modern games. The 7870 is known to run multiple-monitor setups at medium-high settings in newer games and should be a much better solution than running 2 560Ti given the total upgrade price.
wtf is lolcats?
I'd def get a fat hooker if i had to resort to that kinda thing. I feel like they'd be grateful and work harder. Also its more bang for my buck, more real estate for my dollar if you catch my drift. its like the Costco of streetwalkers.
I was hoping for 150 :(.
I was hoping she would let me put it in her butt
For $515 you could get a Radeon 7870 2GB and an adapter for a 3rd monitor: http://www.pbtech.co...5-PCI-E-Video-c
Adapter: http://www.pbtech.co...Male)-to-Single
thanks man, excatly the info i was needing.
would it be worth me spending a touch more and getting the flex edition? http://www.pbtech.co.nz/index.php?z=p&p=VGASAP7876&name=Sapphire-FLEX-HD7870-GHZ-EDITION-2G-GDDR5-PCI-E-Vi
sorry there arent any specs on there but ya know.
and getting parts down here is a bitch! no matter if its audio of PC or anything related haha its all really expensive and we only get half the stuff available
PSN: Rcp_soundz
would it be worth me spending a touch more and getting the flex edition? http://www.pbtech.co...-GDDR5-PCI-E-Vi
The Flex Edition is actually a better option here. Totally forgot Sapphire had that option for a little bit more. It'll come out to $493 for the card but won't require any adapters for your third monitor (assuming your monitors can all use DVI/HDMI). It'll save you about $20 and you won't have to worry about expensive adapters possibly breaking. Good catch on that one!
wtf is lolcats?
do you think ill get away with my current power supply?
http://www.digitalversus.com/lcd-monitor/lg-flatron-e2351-p11664/test.html
they are the monitors ive got. I currently have 2 and will get a third once the funds build up again after buying the card
Edited by RCP Audio
PSN: Rcp_soundz
http://www.digitalve...11664/test.html
Your current PSU will be enough for a 7870.
wtf is lolcats?
