Heres my day....ran wire from the front all the way to the back and soldered all the terminals.  It may seem like overkill but for the distance im running the wire i think its just right.  Todays mission was to run 2 1/0 positive and 2 1/0 negative from the front to rear amp rack as well as a few other 1/0 runs.  Pics may look boring but it was alot of work so i gotta post them!
  Posted Image
  Posted Image
This was me all day on my back from the planning (mapping the runs out) to the 1 at a time pushing, pulling, reaching, and fishing this wire.
  Posted Image
first two runs in time for the second set..
  Posted Image
  Posted Image
  Posted Image
  Posted Image
Follow my Tweet (Twitter)
ok now time to trim them and add the ring terminals....
  Posted Image
no, im not crimping them with the channel locks, my son is holding the wire upright so i can solder 'em up like the rest    :)
  Posted Image
  Posted Image
  Posted Image
everything ziptied from front to rear
Posted Image
  Posted Image
  Posted Image
Posted Image
now i just need to get it into the car, which should be easy since i already cut the hole.  Its late on sunday and im gonna chill for the nite. More pics later!
Ok there is one silver 1/0 going from the battery to the alt bracket, and one going from the battery to a nice chassis ground close by.  Then there is second 1/0 Neg (silver) on the alternator bracket and it runs all the way to the back distribution block (pics to follow).  Then there is another 1/0 silver going from that chassis ground which also has a direct 1/0 back to the battery (-) post.  That cable runs to the rear as well.  Finally when these grounds make it to the back dist. block i also did a chassis ground on that block as well. I guess you could say i went well beyond the "big 3" ;)  There is 2 pos/2neg 1/0 from front to rear as well as rock solid chassis/battery grounds......basicly
here is tonites "after work-work"
Heres some more wiring...got the 1/0 up into the car today.  Its pouring rain and getting late so this is about it for the evening.
  Posted Image
  Posted Image
  Posted Image
starting to come together....
i got a tool that you cant get off the Snap On truck....nothin beats a set of tiny hands!
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
ok here is a little task...first i pulled the door panels off so i can see whats behind them.
Posted Image
nothin like a set of "by 8's" in the doors....gonna replace these with some 6 1/" seperates in the front doors and 5 1/4" seperates in the rear doors.  Of course im going to run all new wires to the doors too.
Ok the door panels were pretty easy but this thing was sorta a pain since ive never dealt with a '05 Navigator before.
  Posted Image
Ok what your looking at here is a module that turns the factory touch screen navigation deck into a working monitor....which it wasnt before for some reason. Everything is still the same but now she can switch to whatever is playing on one of the 2 dvd players that will be in this ride.
  Posted Image
  Posted Image
  Posted Image
  Posted Image
Posted Image
Posted Image
Posted Image
before the dash goes back together i gotta put this in.  Thats tomorrows after work work.
Posted Image
Box is out getting stitched up so probably this weekend im thinkin ill be able to finally run the wire up to the RF amps!
    Posted Image
    Posted Image
    Posted Image
    Posted Image
  Posted Image
the white colored RCA's are the Aux in and were ran to make this thing Ipod ready.
Posted Image
I havent heard the Clean Sweep yet but so far the calibration process seamed to work flawelessly and i did run those rca's out to my boom box just to make sure i had a signal.  I have a good feeling about this  :)
anything that says "scrap if dropped" tends to make me nervous..lucky for me everything went fine.  :)
Posted Image
  Posted Image
  Posted Image
almost all back together.  I think tomorrow i mount switches volume, and bass knobs somewhere in there then im all done with this phase  :)
