show me where I said to pull the door off? I though it was pretty clear that I was talking about the grommets themselves.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
my favorite way of fishing wires is with a scrap piece of copper wire from 14 gauge romex . just sort of bend it as you go , bend the end you push through so it wont snag anything , then when you get it through , generously tape your wire to pull on to your fish wire , making a hook is a good idea . aluminium fence tie wire works good for this too . if it don't pull very easy some silicone spray lube will help , the spray lube that leaves a dry film .
if you pull the gromet off to get your wires through watch for water leaks afterwards , i have ran into gromets not sealing after being disturbed to run wire . if your vehicle is new enough you probably won't run into this .
  • Who's Online   0 Members, 0 Anonymous, 2459 Guests (See full list)
