TylerParrish Posted August 11, 2012 Report Posted August 11, 2012 does anyone know of some programs like winisd? that work on windows 7 (windows 7 home premium 64 bit)? What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
LZTYBRN Posted August 11, 2012 Report Posted August 11, 2012 WinISD works fine for me on windows 7 64 bit...
TylerParrish Posted August 11, 2012 Author Report Posted August 11, 2012 WinISD works fine for me on windows 7 64 bit... it wont save any of my custom subs, it always says the parameters i entered aren't correct even if they are, and i have to use task manager to close it out What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
TylerParrish Posted August 11, 2012 Author Report Posted August 11, 2012 Bassbox pro 6 is a pretty good program thanks, ill go give it a try What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
LZTYBRN Posted August 11, 2012 Report Posted August 11, 2012 WinISD works fine for me on windows 7 64 bit... it wont save any of my custom subs, it always says the parameters i entered aren't correct even if they are, and i have to use task manager to close it out I have the same problems with WinISD Pro. Is that the one you downloaded? If so, then download the regular version. http://www.linearteam.dk/default.aspx?pageid=winisd
TylerParrish Posted August 11, 2012 Author Report Posted August 11, 2012 it is the one i downloaded, however, the regular version is even worse on my computer :/ i got bassbox pro 6 (torrented version), works fine, just complicated as shit What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
Mario928 Posted August 11, 2012 Report Posted August 11, 2012 it is the one i downloaded, however, the regular version is even worse on my computer :/ i got bassbox pro 6 (torrented version), works fine, just complicated as shit I also have the bassbox pro 6 and i dont know how to use it. Its very complicated. Build Under Construction Head Unit = Kenwood DDX514 Amps = Kicker 750.1, Going to install Sundown 1500D v3 and Sundown 125.4 Battery = XS D3400 Wires = Kicker RCA's, 0 Gauge street wire and Stinger Mids and Highs = Stock Sub= Kicker L7 12" Alternator = 220 Mechman Sound Deadner= Fatmat and Stinger Road Kill
TylerParrish Posted August 11, 2012 Author Report Posted August 11, 2012 it is the one i downloaded, however, the regular version is even worse on my computer :/ i got bassbox pro 6 (torrented version), works fine, just complicated as shit I also have the bassbox pro 6 and i dont know how to use it. Its very complicated. ive played around a little bit with it, but i cant do more than enter in stuff for my sub and some basic box designs, everything else goes right over my head What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
