rmk818 Posted August 12, 2012 Report Posted August 12, 2012 I have an amp rated at 4 ohm and my sub is putting out 6 ohms. Will this be a problem for the sub? Will it be a problem for the Amp? I can not add another sub there is no room. Additionally, how can I tell if my sub is bad? It is a Dual voice coil.
Guest Posted August 12, 2012 Report Posted August 12, 2012 what subwoofer? if its wired to 6 ohms on a 4 ohm amp, its fine. the amp just wont output as much power as it can
ch0sen Posted August 12, 2012 Report Posted August 12, 2012 or is it a dual 6 ohm? My current 95 Jetta Build w/ pioneer h/u 2 RD Sonance 10's with flatwind coils 2 Audiopipe apsm 1500.1s 1 Hifonics Brutus Elite 60x4 1 XS d925 1 Stinger spv35 1 1000 amp lead acid 50 ft of 0/1 ofc from Audiotechnix all powerbass components, and coaxils, 4 sets buildlog = http://www.stevemead...2-rd-10s-build/ My build for my wife. http://www.stevemead...01-f-150-build/
rmk818 Posted August 12, 2012 Author Report Posted August 12, 2012 The sub is a JL 10w6v2 and is supposed to have an eight or 2 ohm (depinding on wiring) load. When I put my multimeter to check the ohms, it is only putting out 6 ohms or 1.5 ohms. My amp can handle 2 or 4 ohm loads. The readings were taken at the ends of the wire where they connect to the amp (disconnected form the amp). There is no corrosion on the terminals and the speaker wiring is 14 gauge. There was some light corrosion on the top of the magnet area (white powder) but that was cleaned off.
bkolfo4 Posted August 13, 2012 Report Posted August 13, 2012 You are measuring DC resistance, not impedance. If your amp is 2 ohm stable, wire the sub coils in parallel for 2 ohms (what you are measuring as 1.5). Brian Current system: 1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s Previous systems: 2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz. 1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
severancej Posted August 13, 2012 Report Posted August 13, 2012 Whats the difference between dc resistance and impedance? 98' dodge ram 140A alt Big 3 XS D2700 JVC kd-r310 Rockford T500-1BDCP 2 Sundown E12 Ported 4cubes 35hz Rockford P400-4 2 Infinity reference 3way 6x9 2 Polk DB 5 1/4 2x layer dynamat all doors
bkolfo4 Posted August 13, 2012 Report Posted August 13, 2012 Short response (you can use google search for detailed info): Direct Current resistance is just the resistance of the wire. When Alternating Current is applied, the voice coil becomes an inductor (that is what creates the magnetic field that reacts with the permanent magnet to cause the cone to move). The inductance changes the resistance, and this resistance changes with frequency. Current system: 1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s Previous systems: 2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz. 1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
