lovesounds_0404 Posted August 14, 2012 Report Posted August 14, 2012 i want the port side firing,if i use the torres calc it will be the same?net volume?,freq?,can you give me some advice,max dim is 12h 31w 15 or 16 d,thanks
Joe X Posted August 14, 2012 Report Posted August 14, 2012 Something like this 2 3" to the side double baffle (assuming sa-8v2 of previous request): Enclosure Specifications: Fb = 35 Hz Vb = 1.4 ft^3 External Height = 12 in External Width = 23 in External Depth = 16 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: 2 x Front & Back (3 parts) = 23 x 12 Left & Right Sides = 13 3/4 x 10 1/2 Top & Bottom = 23 x 13 3/4 Port Quantity and Dimensions: Number of Ports = 2 Pipe Port Diameter = 3 Pipe Port Length = 19
lovesounds_0404 Posted August 15, 2012 Author Report Posted August 15, 2012 sir joe can i request for a L-Port?thanks,,
Joe X Posted August 15, 2012 Report Posted August 15, 2012 Ok then this: Enclosure Specifications: Fb = 34 Hz Vb = 1.46 ft^3 External Height = 12 in External Width = 28 in External Depth = 16 in Port Width = 2 1/4 in Port Height = 10 1/2 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: 2 x Front & Back (3 parts) = 28 x 12 Side 1 = 11 1/2 x 10 1/2 Side 2 = 13 3/4 x 10 1/2 Top & Bottom = 28 x 13 3/4 L Port Internal Assembly Parts: Side to Side = 24 1/4 x 10 1/2 Extension = 4 1/4 x 10 1/2
lovesounds_0404 Posted August 15, 2012 Author Report Posted August 15, 2012 sir joe can it be side firing port?,sorry for another request,lol,,,then the subs facing front,,i just want to experiment on my cabin,,
Joe X Posted August 15, 2012 Report Posted August 15, 2012 sir joe can it be side firing port?,sorry for another request,lol,,,then the subs facing front,,i just want to experiment on my cabin,, Changed it but I don't have a pic for that, just make sure the subs are away from the internal end of the port.
Joe X Posted August 17, 2012 Report Posted August 17, 2012 Ok Mr. lovesounds_0404, I have updated the design above and provided a sketch for it, since I know you are a natural skeptic so I will go a step further and explain how is done in Torres: So I start by switching width and depth, like this so that the program does not tell me that the port turn even if it has not: External Height = 12 in External Width = 16 in External Depth = 28 in I calculate a box without a double baffle or it will add the displacement of the wrong face (since I switched depth and width): External Height = 12 in External Width = 15.25 in External Depth = 28 in So the calculation is complete, since the second layer is outside the box and there is no port there I just know that the depth is 16 not 15.25 when I add the second baffle layer. Hope that is all you need.. you can do some changes as you see fit.
