if you have torres, change the width and depth around,
but it only works if you dont double baffle,
if you are double baffling youll need need to minus the baffle in the box od so as not to change the volume
cAn u give some sketch sir john for 2 8"?tnx
now if you'll like some help you need to post some info on you want help with,
car,
power,
sub,
sub/port direction
measurement max, to all walls
measurements you'll like to work within
and your overall goal
car,
power,
sub,
sub/port direction
max dim 12hx31wx15d,for 2 sundown sa8v2,1500 amp,in the left side of the box where i will put the port,it is a sedan,i like lows and a bit of kick in sq,thanks
why side port, there is a possibility, paint cracking due to panel flex with side ported, on the side of port + more panel flex = less output,
ive seen it happen before, (but not with 8's, but these aren't your average 8 either)
the rear wall is too far,,so i just want to experiment,,
when you say the rear wall that mean the sub will be firing the to the centre of the trunk (side firing) and the port to the rear,
you also need to be more specific on the details,
1500 amp is what, 1500watts,1500rms each, both,
also need trunk dimensions,
we no what you will to give up 12x31x15
Edited by john253a
the port is firing on the left side of the,thats why its side firing,,the subs will fire to the trunk lid, so its rear firing,,sundown saz 1500d
