OK guys,
the system has grown up a little.
We started by searching for a new setup, ended up designing the enclosure in Sketchup.
After the design was taken care of, we began removing the old setup.
Then we began cutting the new enclosure.
Of course, I couldn't have done it without my little helper.
Test fitting, double checking box height, baffle size, and seat slope.
By this point I was realizing that the rear cargo latches would need to be removed.
Clamping everything together. Gotta sand everything and get nice clean lines. (still had to figure out backwall angles and make final cuts.
Got the hardware together for final assembly.
Love these screws, no predrilling!!!!
My loving girlfriend, laying out the baffles so I can make my cuts for the port.
Figuring out the port was probably the hardest and most frustrating part of this build. I went through a few design changes, but finally settled on one that I'm more than happy with. Dealing with the limited space of this hatchback, I made the port 1-common wall, and the front of the port extends over across the enclosure and serves as the amp rack.
2011 Chevrolet Aveo(click for build log)
Clarion NX-603
SKAR 4500.1D
Iraggi 320A alt
Knukonceptz 1/0 Kollosus Fleks Cable
8 AWG Sky High Car Audio OFC
1/0- Sky High Car Audio
2- XP3000 XS Power Batteries
SMD VM-1
2- 12" Ascendant Audio Mayhems
Toolmaker Fuse block
Toolmaker Bus Bars
(Last Season scores 1-15" Mayhem)
145.2 dB- Sealed @ NSPL World Finals (9/28/14)
148.1 dB- Hardcore @ NSPL World Finals (9/27/14)
150.23-- Hardcore on 4500 Watts!!!!
New Build (2015, 2-12" Mayhems)
146.9- Sealed on dash
149.6 dB- Hardcore in Kick (No wall 0-24" Hardcore)
Here, I was testing the lines of the port, making sure everything lined up.
The inside port will need to be painted before assembling it, or placing it into the baffle. For this we have chosen metallic blue paint.
Base coat of black
Second coat is a silver, which adds a "flake" to the blue metallic (these are rattle cans).
The last coat is the metallic blue.
Clarion NX-603
SKAR 4500.1D
Iraggi 320A alt
SMD VM-1
Toolmaker Bus Bars
The paint had to be taped over to protect it during the rest of the install. Test fitting the port into the baffle again.
Giving myself a little visual motivation.
Clarion NX-603
SKAR 4500.1D
Iraggi 320A alt
SMD VM-1
Toolmaker Bus Bars
Next step was notching out the baffles. Here's one of the baffles notched out.
Now that we've gotten this far, time to glue and screw in the first baffle. Notice, the block sitting under the amp rack, it's allotting space for the second baffle. Don't notice my shop, it is in dire need of a serious cleaning, but that's after this project ;-)
I used the battery to hold down the port while the glue dried.
Clarion NX-603
SKAR 4500.1D
Iraggi 320A alt
SMD VM-1
Toolmaker Bus Bars
Got a few goodies in.
Hydraulic crimps!
Battery Terminals
Clarion NX-603
SKAR 4500.1D
Iraggi 320A alt
SMD VM-1
Toolmaker Bus Bars
Knukonceptz Kollosus 1/0
Tsunami 200 Amp Circuit Breakers
Clarion NX-603
SKAR 4500.1D
Iraggi 320A alt
SMD VM-1
Toolmaker Bus Bars
Can't forget the security screws and T-nuts for the sub and amp rack!!!
Couldn't spring for a new system and not have it setup right... A slightly used DD-1
Time to get back to work!
Cheap Chinese voltage gauge.
It was only two-wire, so had to wire it to a relay.
Clarion NX-603
SKAR 4500.1D
Iraggi 320A alt
SMD VM-1
Toolmaker Bus Bars
Initially, had it located on dash.
I began to dislike the location, so moved it up onto the pillar.
Time for wiring
Clarion NX-603
SKAR 4500.1D
Iraggi 320A alt
SMD VM-1
Toolmaker Bus Bars
Out with the old.
In with the new.
Clarion NX-603
SKAR 4500.1D
Iraggi 320A alt
SMD VM-1
Toolmaker Bus Bars
