Twostrokeking Posted August 20, 2012 Report Posted August 20, 2012 Earlier this morning I was driving my truck and my amps were working fine, everything sounded great. I went out a little bit ago and turned the truck on, the stereo came on but I had no noise. First thing I did was check the amps, both were off. I checked under the hood and the amp fuse was just fine. I am getting 12 volts at both amps, 12 volts at the remote wires. I replaced the fuse on the deck and in the fuse panel.. I wiggled the grounds and both are tight as they always have been.. What the hell is the problem?! I am freaking out! My Truck BuildSpending money on things I don't need, to impress others I don't know.At the end of the day for me its about the love of customizing anything and everything to limits or even past reasonable.-SkyHighCarAudio
dog24fret Posted August 20, 2012 Report Posted August 20, 2012 Have you checked the voltage on the rcas sir. Cowboy Escort GrAnny ThUmper The Burp
AMI CUSTOMS Posted August 20, 2012 Report Posted August 20, 2012 Did you check at the amp with a DMM to make sure you are getting 12 volts from the battery and from the deck remote wire when the deck is on? Also does your deck have a sub on/off function? TEAM SOUNDQUBED -- TEAM SOUTH TEAM S.O.B. - Founder & Captain 3x Streetbeat World Record Holder 2017 MWSPL 1st place Mayhem & 4th Xtreme 4 2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4 2015 MWSPL 2nd place Mayhem & 4th Xtreme 4 2014 USACI 2nd place Streetbeat 5 - 162.6 db 2014 MWSPL 2nd place Xtreme 4 - 144.9 db 2013 USACI 1st place Streetbeat 4 - 161.9 db 2013 USACI 1st place Street Q+ - 162.8 db 2013 MWSPL 3rd Kaos2 & 4th Xtreme 4 2011 USACI 2nd place MOD 1001-2k - 160.0 db 2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db 2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest Best score to date 164.4 db - Termlab Outlaw Streetbeat 4 - 161.9 db Streetbeat 5 - 162.6 db MWSPL on Dash Legal door open (Music) - 162.5 db Sealed on dash Legal (Music) - 161.1 db - Termlab THE BLACK NASTY CURRENT BUILD & FAB The Black Nasty (6) 15 Rebuild Log 2012 (4) 15 Walled Sierra Build Log Evo X build log Facebook page The Black Nasty
Twostrokeking Posted August 20, 2012 Author Report Posted August 20, 2012 Have you checked the voltage on the rcas sir. Haven't done that, but the lights on the amps arent coming on My Truck BuildSpending money on things I don't need, to impress others I don't know.At the end of the day for me its about the love of customizing anything and everything to limits or even past reasonable.-SkyHighCarAudio
Twostrokeking Posted August 20, 2012 Author Report Posted August 20, 2012 Did you check at the amp with a DMM to make sure you are getting 12 volts from the battery and from the deck remote wire when the deck is on? Also does your deck have a sub on/off function? Yeah I metered the inputs at both amps and I get 12 volts. remote wires each get 11. Deck does have on and off but I checked it. My Truck BuildSpending money on things I don't need, to impress others I don't know.At the end of the day for me its about the love of customizing anything and everything to limits or even past reasonable.-SkyHighCarAudio
01VWGREENMACHINE Posted August 20, 2012 Report Posted August 20, 2012 did you check the fuses in the amps? check your grounds attached to the frame. not just on the amp side http://www.stevemead...f-system-build/ 2001 VW GTI with a 1.8T motor BIG 3 Pioneer AVH-4200DVD DOUBLE DIN HEAD UNIT 6 - 4 VOLT PREOUTS RF T1500-BDCP (running at 2 ohm) RF T400.4 RF T1 D212 x2 (in ported box) RF 1/0 TO 4 GAUGE distribution block x 2 all stinger wires 200a alternator (SINGER ALT) RF T2652-S (6.5 MID BASS AND 1" TWEETS in front and rear) KINETIC HC 800 BATTERY (Front) KINETIC HC 1200 BATTERY (BACK) 120ft of 1/0 stinger blue and clear matt 20ft of 4 gauge stinger blue and clear matt 30ft of 8 gauge stinger blue and clear matt 100ft of 12 gauge stinger speaker wire black
Crandis16 Posted August 20, 2012 Report Posted August 20, 2012 that's strange that it was both amps..... is there any type of internal fusing by any chance? My Red zx2 Build Log My Black zx2 Build Log My Red zx2 UBL
AMI CUSTOMS Posted August 20, 2012 Report Posted August 20, 2012 List what amps they are so I don't have to dig for it lol. TEAM SOUNDQUBED -- TEAM SOUTH TEAM S.O.B. - Founder & Captain 3x Streetbeat World Record Holder 2017 MWSPL 1st place Mayhem & 4th Xtreme 4 2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4 2015 MWSPL 2nd place Mayhem & 4th Xtreme 4 2014 USACI 2nd place Streetbeat 5 - 162.6 db 2014 MWSPL 2nd place Xtreme 4 - 144.9 db 2013 USACI 1st place Streetbeat 4 - 161.9 db 2013 USACI 1st place Street Q+ - 162.8 db 2013 MWSPL 3rd Kaos2 & 4th Xtreme 4 2011 USACI 2nd place MOD 1001-2k - 160.0 db 2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db 2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest Best score to date 164.4 db - Termlab Outlaw Streetbeat 4 - 161.9 db Streetbeat 5 - 162.6 db MWSPL on Dash Legal door open (Music) - 162.5 db Sealed on dash Legal (Music) - 161.1 db - Termlab THE BLACK NASTY CURRENT BUILD & FAB The Black Nasty (6) 15 Rebuild Log 2012 (4) 15 Walled Sierra Build Log Evo X build log Facebook page The Black Nasty
b-dubs89 Posted August 20, 2012 Report Posted August 20, 2012 thats odd that you only get eleven volt on the remote turn on . if it were me i would try a jumper wire from positive terminal on amp to remote and see if it turns on . i had a fuse blow once and it wasn't obvious to look at it and it still got 7 volt through it on the dmm , but not enough to run anything .
dog24fret Posted August 20, 2012 Report Posted August 20, 2012 Have you checked the voltage on the rcas sir. Haven't done that, but the lights on the amps arent coming on Yea no point in checking the rcas if the amps aren't comming on at all. Didn't catch that part sorry. Is it posiable the ground went bad. The ends or wire cause this is weird for mutiple failure it has to be common for all amps. Like the rest said. If you can easily run a temp ground to see if that makes a diff that's the only thing I can think of. Cowboy Escort GrAnny ThUmper The Burp
