PLEASE HELP ME ASAP!
Twostrokeking
thats odd that you only get eleven volt on the remote turn on . if it were me i would try a jumper wire from positive terminal on amp to remote and see if it turns on . i had a fuse blow once and it wasn't obvious to look at it and it still got 7 volt through it on the dmm , but not enough to run anything .
Just went and tried that. The mids and highs amp will come on and the subs amp sits and flickers.
My Truck Build
Spending money on things I don't need, to impress others I don't know.
At the end of the day for me its about the love of customizing anything and everything to limits or even past reasonable.-SkyHighCarAudio
List what amps they are so I don't have to dig for it lol.
Fosgate bd1000 and an alpine v12
My Truck Build
Check them grounds then
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
ALSO! The deck remote also turns on my volt meter.. the volt meter works fine.
My Truck Build
i would then look at your ground(s) . maybe try a jumper cable to your batt negative and see what you get
Ill go try it real fast
My Truck Build
My terminal end on my ground went bad due to corrosion cause I didn't protect them. Hopefully it's simple. Ahhhhhh that flea still haven't got used to it poor iPad lol.
that there is why i like to solder terminals
i agree
drain all the power out of your Rockford by disconnecting it for a couple of hours and try powering it back up my 4 channel did that i just disconnected everything and waited like 2 hours and connected it back up and everything works great.
http://www.stevemead...f-system-build/
2001 VW GTI with a 1.8T motor
BIG 3
Pioneer AVH-4200DVD DOUBLE DIN HEAD UNIT 6 - 4 VOLT PREOUTS
RF T1500-BDCP (running at 2 ohm)
RF T400.4
RF T1 D212 x2 (in ported box)
RF 1/0 TO 4 GAUGE distribution block x 2
all stinger wires
200a alternator (SINGER ALT)
RF T2652-S (6.5 MID BASS AND 1" TWEETS in front and rear)
KINETIC HC 800 BATTERY (Front)
KINETIC HC 1200 BATTERY (BACK)
120ft of 1/0 stinger blue and clear matt
20ft of 4 gauge stinger blue and clear matt
30ft of 8 gauge stinger blue and clear matt
100ft of 12 gauge stinger speaker wire black
hey I had the same problem at one point..... I had trunk battery (not hooked up to alt) hooked up to power and ground and remote was coming from HU. the amp wouldn't turn on because of different voltages. When I ran a remote wire from trunk batt to amp it did turn on because it was reading same voltage.
  • Who's Online   1 Member, 0 Anonymous, 1972 Guests (See full list)
