CJs F150 2012 Edition UBL
Equipment List
Subs- 4 DC m2 Level 5 15s.
Sub Amps- 2 DC 7.5ks
Mids- 16 AA Carbon Mids and 8 Crescendo PWX 8s
Highs- 12 Crescendo FT-1
Mids Amps- 2 200.4s
Highs Amp- 100.4
Processor- Rockford 360.3
Electrical- 1 Mechman 340a(12v) and 1 Singer 400a(14v)
Batteries- 14 XS D1400s and 7 XS S1400s for 14v side. 1 XS D6500 and 2 XS D3100s for 12v side.
Time to tear down! Just started raining so I am inside for a bit. Once it stops I have to go pick up 20 sheets of wood.
  • 3 weeks later...
Got wire?
6 20'+ runs of 2/0 welding cable. Got this from Blake when he parted out the burb.
New 200' spool of 1/0 welding cable
Left to right.
Knu 1/0 OFC, Knu 1/0 CCA, 2/0 welding cable, 1/0 welding cable
Oh........ The build will start tomorrow. I have been waiting for the wire to come in so I can get my 12v runs into the cabin before I build the wall.
As promised, PICTURES!!!!
First task for the day was to get the grommets installed so I can run wires safely into and out of the cab. I had perviously just drilled holes and used deadener to keep the edges from cutting the wire. Not anymore!
Wire before and after installed techflex
I decided to run a new power wire from the front 12v to the back where I will have 2 D3100s.
And for those who asked about the battery rack and amp rack. I still have to pull the batteries out and drill more holes in the buss bars for all of the exra runs I am going to need. You can see the space that I left for 3 more and then there is a d3400 in the back right corner that is coming out and the 14th 1400 will go back there.
