My dad was wanting to but some sound deadener in his 06 nissan titan, We were discussing it and I was telling him he should go with something like second skin, or to save some money put something like Raam mat, stinger or something of that matter in the truck but he was calling around town and found a local shop that sells BALLISTIC SOUND DEADENEner I have never hear of it but the shop selling it of course stand behind it, it is supposed to be 2.1mm thick anyone know anything about this
disregard
Edited by 97Jetta1637
#teamihop
Two 12 inch DC XL's
Carbon Fiber Cap
Stetsom 7k
Shell of box / baffle built by me
Port / sealing the box by John Hone
Fuck midrange
Alpine-9886
http://www.stevemeadedesigns.com/board/topic/177428-97jettas-sql-trunk-wall-loudest-99-buick-century-custom-with-a-one-legged-owner/
price has no influence on how something sounds
I told him to move the fucking port.
they see me hoppin they stoppin they can't believe im so white and dirty
It looks like you got so drunk, that someone came up and stole your leg.
there is a difference between milimeters and mills
second skin is 60 mills 60 millimeters is over 2 inches lol
yah i noticed that when i scrolled up to top and it said 60 mills and i was like, oh.
#teamihop
Two 12 inch DC XL's
Carbon Fiber Cap
Stetsom 7k
Fuck midrange
Alpine-9886
So if that 2.1millimeters is correct its probably a 80mil product which is like second skin damp pro i believe. If it is reasonable priced and has a 6+mil foil with butyl backing its probably a solid product
Team NorthWestSPL
this is the specs I found online for Ballistics
he SSBK bulk kit contains 9 18" x 32" pieces
Total Coverage: 36 sq ft.
$179.95
SPECIFICATIONS
Appearance:
Black Butyl Based Material With 4 Mil Aluminum
Constraining Layer, With Craft
Paper Release Liner
THICKNESS: NOMINAL
Thicker than the competition
0.083” (2.1MM)
MASS:
GREATER THAN 0.73LBS./SQFT
(2.55kg/M2)
TEMPERATURE RANGE:
OPTIMAL PERFORMANCE
14°F TO 140°F (-10°C TO +60°C)
ADHESIVE PEEL STRENgTH:
MINIMUM 43 LB./IN. (75 N/CM)
ON COLD STEEL
CHEMICAL RESISTANCE:
RESISTANT TO WATER
AND MINERAL OILS
FEDERAL STANDARDS TESTS:
MEETS: FMVSS 302
Unless you are anticipating some extreme flex you are trying to deal with I would just buy stinger roadkill expert. Comes in the same size (or similar size sheets) 36 sqft for $120. And it has a thicker foil layer. I would bet for your dads application he would not be able to tell the difference between the two and the stinger is cheaper.
Edit: the stinger might even reduce flex better since it has a thicker foil layer, I really don't know how those properties work exactly
Edited by mrd6
Team NorthWestSPL
Since the question of Ballistic came up in our sub forum, I'll provide ya with my information.
Ballistic is a product made for and sold by Metra.
It is made in China. Comes in either a sheet or wedge roll.
They list it as 83 mils thick, and it measures up to those specs (surprised the hell out of me).
It comes with a 4 mil soft aluminum. THIS is where the product suffers. Since it has a thinner constraining layer than several other products on the market, it doesn't perform quite as well (even though it has a lot of mass/extra thick butyl). Kinda of a waste pairing that much butyl with a rather thin piece of aluminum.
The adhesive is fair to good, no worries about it failing like an asphalt or bitumen based mat.
Overall it's a rather typical product right in the middle of the field. Nothing special.
Have a question about Second Skin? E-Mail me!
  • Who's Online   0 Members, 0 Anonymous, 1041 Guests (See full list)
