happileej Posted August 26, 2012 Report Posted August 26, 2012 Just wondering what the best way would be to go about making my own fender flares out of fiberglass I want to fit them to a 1993 Mazda 121 Db Thanks
412 CVX Posted August 26, 2012 Report Posted August 26, 2012 only 121 DB? maybe it'll be louder after you add the flares. best of luck broski Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid.
vibrator Posted August 26, 2012 Report Posted August 26, 2012 you could either spray paint some bolt on flares which would leave a gap or bolt some flares on bondo over them and then spray which then youll need to spray the whole pannel. Henry Ford once received a letter from a depression-era bank robber responsible for the deaths of several law enforcement officers, killed in their attempt to stop him as he fled the crime scene. In his letter, he thanked Mr. Ford for making his Model A Ford such a good getaway car.
happileej Posted August 26, 2012 Author Report Posted August 26, 2012 you could either spray paint some bolt on flares which would leave a gap or bolt some flares on bondo over them and then spray which then youll need to spray the whole pannel. Where would I get bolt on flares to fit my mazda? I thought I would have to custom make them to fit. Thanks
happileej Posted August 26, 2012 Author Report Posted August 26, 2012 only 121 DB? maybe it'll be louder after you add the flares. best of luck broski Sorry its a Mazda 121 Bubble. Db is the model. LMFAO
HunterJohnson Posted August 26, 2012 Report Posted August 26, 2012 Go to groundpounder2k section. There's alot of pictures to learn from, but you're going to have to use foam and sanding to get the shape you want. Then glass the foam Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass
happileej Posted August 27, 2012 Author Report Posted August 27, 2012 Go to groundpounder2k section. There's alot of pictures to learn from, but you're going to have to use foam and sanding to get the shape you want. Then glass the foam Yeah I thought that might be the only way to go, thanks for the reply
