TylerParrish Posted August 28, 2012 Report Posted August 28, 2012 my gains are set with the dd1 with the -5 tone.i am reading my voltage straight from the amp now i have to wonder why my voltage is dropping so low..... >_> gains might be set to high man might be, I'm not sure, have my gain just under half, no bass boost, and i normally never play at full tilt, keep it about half way on the on the bass knob. well like I said, I think this box is 1cube too big and was meant for higher RMS than the sub can handle ive got less or equal than the sub can handle so I think that's why I have it at 3/4. I think my first step will be a smaller box. maybe 2.5 cubes? smaller would accommodate for lower power handling right? bigger boxes normally mean they handle less power. what kind of sub do you have, build the box to the specs for your sub(s). What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
TylerParrish Posted August 28, 2012 Report Posted August 28, 2012 my gain is rite around 1/3. 2.5 volts coming from my headunit,i checked it with a dmm. well shit, my radio has 5 volt pre-outs, i havent checked if im actually getting that....i know what i'm doing tomorrow! i cant exactly set mine with a dd-1 since i dont have access to one, but my voltage never drops below 12.6 for now >_> urggg What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
wellington Posted August 28, 2012 Author Report Posted August 28, 2012 my gains are set with the dd1 with the -5 tone.i am reading my voltage straight from the amp now i have to wonder why my voltage is dropping so low..... >_> gains might be set to high man might be, I'm not sure, have my gain just under half, no bass boost, and i normally never play at full tilt, keep it about half way on the on the bass knob. well like I said, I think this box is 1cube too big and was meant for higher RMS than the sub can handle ive got less or equal than the sub can handle so I think that's why I have it at 3/4. I think my first step will be a smaller box. maybe 2.5 cubes? smaller would accommodate for lower power handling right? bigger boxes normally mean they handle less power. what kind of sub do you have, build the box to the specs for your sub(s). american bass VFL extreme 15" dual 2 ohm. the older one. its not on AB's website. 2010 HHR LT - DNX 6160 - sony xec-700 - sony xm-4040 for door mids - XM-6020 for tweets in a-pillar - saz1500d v1 - VVME RD-12 1.75 f^3 32hz guru and president of the "cheap asses trying to beat up the block with bargain bin woofers" club
TylerParrish Posted August 28, 2012 Report Posted August 28, 2012 my gains are set with the dd1 with the -5 tone.i am reading my voltage straight from the amp now i have to wonder why my voltage is dropping so low..... >_> gains might be set to high man might be, I'm not sure, have my gain just under half, no bass boost, and i normally never play at full tilt, keep it about half way on the on the bass knob. well like I said, I think this box is 1cube too big and was meant for higher RMS than the sub can handle ive got less or equal than the sub can handle so I think that's why I have it at 3/4. I think my first step will be a smaller box. maybe 2.5 cubes? smaller would accommodate for lower power handling right? bigger boxes normally mean they handle less power. what kind of sub do you have, build the box to the specs for your sub(s). american bass VFL extreme. the older one. its not on AB's website. American Bass's website is stuck in the past unfortunately. I would start a new thread asking about people's experience with the sub and suggestions for a box. Also, if u have no experience with box building, you might wanna have someone design you one. What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
ineeDBass419 Posted August 28, 2012 Report Posted August 28, 2012 mine has 4v preouts but i have the sub output at only 7 out of 15.its a kenwood kdc-x696 xbox 360 gamertag-greenrocks420 Not insulting you or anything, but did you just call us "bloody winging fairies" ?
wellington Posted August 28, 2012 Author Report Posted August 28, 2012 mine has 4v preouts but i have the sub output at only 7 out of 15.its a kenwood kdc-x696 do you mean the sub control? Does it have - and + and are you saying you have it on +7 out of + 15? mine has a 0 setting and then +10 and all the way down to minus 50 2010 HHR LT - DNX 6160 - sony xec-700 - sony xm-4040 for door mids - XM-6020 for tweets in a-pillar - saz1500d v1 - VVME RD-12 1.75 f^3 32hz guru and president of the "cheap asses trying to beat up the block with bargain bin woofers" club
TylerParrish Posted August 28, 2012 Report Posted August 28, 2012 mine has 4v preouts but i have the sub output at only 7 out of 15.its a kenwood kdc-x696 aresnal's dont clip until volume 48/50, and that's with the sub out at 8/8, so i just keep it at 8. What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
ineeDBass419 Posted August 28, 2012 Report Posted August 28, 2012 yea its at +7.it goes form -15 to +15.at +15 the preout is 4v. if yours is 5v preout and your amp is rite around 1/2,then its possible that your clipping.dont quote me on that though,im just saying its possible xbox 360 gamertag-greenrocks420 Not insulting you or anything, but did you just call us "bloody winging fairies" ?
TylerParrish Posted August 28, 2012 Report Posted August 28, 2012 yea its at +7.it goes form -15 to +15.at +15 the preout is 4v. if yours is 5v preout and your amp is rite around 1/2,then its possible that your clipping.dont quote me on that though,im just saying its possible oh welll, i'll find out when i meet up with someone in NC with a DD-1, but for now, i dont play it at all since i wont have my license back til october 4th. hopefully i can find someone with one, or maybe even purchase one by then. Maybe it'll be a birthday present since my birthday is the day after What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
wellington Posted October 26, 2012 Author Report Posted October 26, 2012 yea its at +7.it goes form -15 to +15.at +15 the preout is 4v. if yours is 5v preout and your amp is rite around 1/2,then its possible that your clipping.dont quote me on that though,im just saying its possible oh welll, i'll find out when i meet up with someone in NC with a DD-1, but for now, i dont play it at all since i wont have my license back til october 4th. hopefully i can find someone with one, or maybe even purchase one by then. Maybe it'll be a birthday present since my birthday is the day after anyone cracked one open yet? how hard can they be to make? 2010 HHR LT - DNX 6160 - sony xec-700 - sony xm-4040 for door mids - XM-6020 for tweets in a-pillar - saz1500d v1 - VVME RD-12 1.75 f^3 32hz guru and president of the "cheap asses trying to beat up the block with bargain bin woofers" club
