My lights still dim even with a second battery.
wel do the batts then also might be a long shot but try to see if you have any alt repair places in town they might be able to squeez a lil more into it maybe 150-200 never know its worth the tryi am surprised mechman couldent do it though
I just got my XS POWER D2400 Battery from FedEx today bought it from AudioSavings. This is a drag the warning label says i have to charge it before i use it but im using it for the battery under the hood is it okay if the alternator charges it? Also AudioSavings says it came with the M6 Terminal Hardware but it doesn't have the Brass Terminal Posts how do i even come upon putting this under the hood without terminal posts? it only came with screws... i really need advice and i don't want to spend anymore money maybe just a couple bucks what local stores in sacramento sells terminal posts?
My Battery Tester says the battery is good do i still needa charge it?
the M6 hardware is just the screws that go into the top posts. they dont come with the brass top posts.
look at the link: http://www.crutchfie...rass-Posts.html
and fyi, alternators make power, not batteries. an alt with some decent reserve will make a world of difference.
you know any local store in sacramento that would sell the Brass Terminal Posts? i need this battery in asap. and mmm if my battery tester says its good then its good to put it in right without charging it?
