would this design be better for 2 12" kicker comps?
caraudiolove
IMO too much port area for such weak subs, and your port needs to stay the same width throughout the entire length of the port. You only cut the port width in half if you're splitting the port in half and end up with two smaller ports...most commonly done when running a port down the middle of the box and splitting it at the rear.
Ryan Miskin - owner of RAM Designs
I have my PM's turned off, please email at <script data-cfhash='f9e31' type="text/javascript"> /* */</script>
2200+ designs since March 2011...
too much port area.
the bend of the port has to stay the same width as the opening of the port. so the width stays 5" all the way through, in this case.
edit: ram ninja :(
You are going to put the port externally but you have 2 common walls, how does that work?
I'd like to see the design on this in sketchup or something sounds cool.
edit:
nevermind, lol
lol i didnt even notice that.
you put 34.5" for external port. that means the entire port is external to the box. there is no port on the inside, like the sketchup shows.
i'm detail oriented ;)
  • Who's Online   1 Member, 0 Anonymous, 1262 Guests (See full list)
