Guest Posted September 8, 2012 Report Posted September 8, 2012 just make the first port piece long enough til its 5" away from the back of the box. then put the 90 degree bend on it. dont put the bend piece on the end of the first port piece. put it on the side of it. like this.
Guest Posted September 8, 2012 Report Posted September 8, 2012 port bend is No in the first picture because you set the calc to put the entire port outside of the box. it will say Yes once you take the 34.5 out of the External port box.
Jessica Posted September 8, 2012 Report Posted September 8, 2012 And your design is a 3 common wall box not 2 Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
caraudiolove Posted September 8, 2012 Author Report Posted September 8, 2012 thanks and would that be enough port area because in the kickers website they say max vented box volume says 63.7
caraudiolove Posted September 8, 2012 Author Report Posted September 8, 2012 ok im stuck on building the port now because the first port wall is 13 3/4D and that would not be enough room for the second port wall
Jessica Posted September 8, 2012 Report Posted September 8, 2012 are you measureing down the center of the port or using the actual port wall for your measurement? Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
Guest Posted September 8, 2012 Report Posted September 8, 2012 63.7 is liters dude. which is 2.25cuft. how do you not have enough room for a bending port? unless the subs are two feet deep, i dont see that happening.
caraudiolove Posted September 8, 2012 Author Report Posted September 8, 2012 no i mean the other wall is going to hit the side
TylerParrish Posted September 8, 2012 Report Posted September 8, 2012 just make the first port piece long enough til its 5" away from the back of the box. then put the 90 degree bend on it. dont put the bend piece on the end of the first port piece. put it on the side of it. like this. why do you do it like that? I never knew it made a difference as long as the dimensions were still right What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
Guest Posted September 8, 2012 Report Posted September 8, 2012 well it doesnt matter. you can do either one as long as you account for the added depth if you choose to do the one that is X'd out.
