TylerParrish Posted September 10, 2012 Author Report Posted September 10, 2012 in that box you posted i would draw a line across the end of the port from the inside corner of the port wall (where it starts in the box) to the other port wall. Then you can just select the bottom of the box and get the area. i did that actually, for a different reason, but i did do it. What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
Jessica Posted September 10, 2012 Report Posted September 10, 2012 I just do it to verify that torres is giving me an accurate number for my net volume. I'm ocd about stuff like that so i like to cross check and re-check about a dozen times to make sure i am getting good numbers. Rest in peace, walled 87 accord build log 03' Corolla build with AA Mayhem inside. My super random youtube channel and terrible camera work. Wiring comparison by CaptainzPlanetz Wire and fuse guide by Guest SyKo13
TylerParrish Posted September 10, 2012 Author Report Posted September 10, 2012 I just do it to verify that torres is giving me an accurate number for my net volume. I'm ocd about stuff like that so i like to cross check and re-check about a dozen times to make sure i am getting good numbers. not as big of a deal to me, I'm more OCD when it comes to things being organized. Every wire I have will be zip tied to something, I try to have all the same brand, and every zip tie will be turned so that you can't see the connector. What the f**k is an appropriate signature supposed to look like?2013 Kia Forte Koup Pioneer AVH-X4600BT iDMax 12 DD M1c @ 2 ohms Rockford Prime 200.2 Pioneer 6.75" Comp Set XS S3400, D2700 Project DB Battery Terminals Axxess ASWC Stinger HPM Everywhereeee 90 Sq. Ft. of Stinger Roadkill Stock Alt Stuff To Come Sundown X-12 New Amp New Comps 4 Channel Amp My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/ My Old Build: http://www.stevemead..._+2000 +mustang Avatar Courtesy of SnowDrifter
