How to figure the displacement off oddly shaped things?
I just threw an estimate as to how much the extra stuff i have in my box will be displaced...but how do i figure out actual displacement so i can get an actual number? Mostly talking about cylinders and 45's...here's a pic of the box for a better idea:
What the f**k is an appropriate signature supposed to look like?
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
Rockford Prime 200.2
Pioneer 6.75" Comp Set
XS S3400, D2700
Project DB Battery Terminals
Axxess ASWC
Stinger HPM Everywhereeee
90 Sq. Ft. of Stinger Roadkill
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
My Current Build: http://www.stevemeadedesigns.com/board/topic/167462-13-kia-forte-koup-dd-setup/
My Old Build: http://www.stevemead..._+2000 +mustang
Avatar Courtesy of SnowDrifter
Posted twice, sorry, someone please lock/delete on of em if you may
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
You can kinda estimate in ur case. In really oddly shaped thing but area bags of packing peanuts and you can fill the enclosure to find how many cubes you've got
thanks man, ill try that once it's built
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
Double click the item, right click, select area->selection
fuckkk yessss, ill go try that, even better :D
2013 Kia Forte Koup
Pioneer AVH-X4600BT
iDMax 12
DD M1c @ 2 ohms
XS S3400, D2700
Axxess ASWC
Stock Alt
Stuff To Come
Sundown X-12
New Amp
New Comps
4 Channel Amp
no problem!, i edited my post so it was more clear what to do. My brain got ahead of my fingers. You may not have to double click on some things
the 45 is a triangle. so just figure the volume of the triangle and take it away from the box. a cylinder is (pi(r^2) * length) / 1728
Volume of a cylinder is calculated as V= pie x radius Squared X height then divide by 1728 to come up ft^3 or use this link http://www.mathopenref.com/cylindervolume.html
To find the formula for displaceement of your 45's http://www.mathwarehouse.com/solid-geometry/triangular-prism/formula-volume-triangular-prism.php or there is a calculator here http://calculator.tutorvista.com/math/30/volume-of-triangular-prism-calculator.html
Edit: thx for catching my mistake Torres :)
  • Who's Online   0 Members, 0 Anonymous, 949 Guests (See full list)
