2 18's low-end monster
MIKE-2U
Did you use mdf ?
Lol....it would be easier if I just gave you the link to the build. The short answer is yes, 1.25" MDF. The long answer will be found in the link below...
http://www.stevemead...deo-on-page-11/
Wow box looks amazing! the only reason i asked is because i dont know if i want to spend all that money on birch the first dual 18's box i build. in the future, yes i will as i better my skills. I dont have a table saw so its impossible to cut good cuts. so you used 1.25" mdf single layer ? The only issue i worry is that it will be so heavy the air ride suspension will have issues. .
I've got air ride also with no prob. Box is probably somewhere around 200 pounds empty, which is like having a person or some tools on the back. If your truck can't handle that, it isn't a truck.
As far as not having a table saw, that's easy. Your box will be so big that you could only use a table saw on a few of the cuts anyway unless you had a monster shop saw table. You can always make perfect cuts every time by placing a straight edge on your piece held down by two squeeze clamps and run a circular saw up against the straight edge. That is how I made all my cuts for my box, even the angled ones. I use an old 4' level as my straight edge, but you could use anything that you're sure is 100% straight, even a cutoff from the sheet of ply or MDF.
2006 Cadillac Escalade
2/3 drop on 28" wheels
Two RE SX 18" subs
RF T2500-1bdCP amp, 3531watts on birthsheet
Custom carbon fiber sub box
EVERYTHING else is stock, for now
149.4 @ 37hz, Termlab, dash, open window on two AQ3 18s all stock electrical, wired to .25 ohm on a RF T2500
148.8 @ 36hz, Termlab, dash, open window on one AQ3 18 all stock electrical, wired to .5 ohm on a RF T2500
147.8 @ 38hz, Termlab, legal, sealed on two RE SX 18s
146.4 @ 36hz, Termlab, legal, sealed on one RE SX 18
Link to my hack-built, stupid, carbon fiber wasting project.... http://www.stevemeadedesigns.com/board/topic/149946-carbon-fiber-box-update-1494db-37hz-on-tl/
http://gifsoup.com/NDM3MTc1MQ
Thanks a bunch. I had no doubt the air ride could handle it ibwas just wondering. I have a radial arm saw actually. I hope to start building in a week. Just looking for a 3-D rendering so i know hownto port it.
2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable
(2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <-------
Needs more power those woofers will laugh at that turd
  • Who's Online   0 Members, 0 Anonymous, 1112 Guests (See full list)
