MIKE-2U Posted September 10, 2012 Report Posted September 10, 2012 Hey SMD well the time has come to do some pre-planning for my upcoming build. I plan to run 2 18" Fi sp4's in a ported box in a Lincoln Navigator. I would like the box to be below the window line if possible. I DO NOT have the exact measurements ATM but can get them tomorrow after work. I believe its around 40 wide 35 deep and 18 tall. What i want to achieve ? A loud N' low daily driver not a burp machine. Will be running one aq 3500.1 off the 2 subs and eventually will get another amp to strap the two. I am looking for a design and sketch-up if possible. Any other input will be noted, thanks allot! 2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable (2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <------- Needs more power those woofers will laugh at that turd
SnowDrifter Posted September 10, 2012 Report Posted September 10, 2012 How low are you looking for? You should be able to play mid 20s no problem if you tune to 30 ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
SWIFT Posted September 10, 2012 Report Posted September 10, 2012 My SP4's are tuned at 30 and slap hard. You will not be dissapointed 2012 F250 Lariat 6.7, lifted on 22's and 35's 4 DSS Ethos 18's walled tuned low 2 Ampere Audio 7500.1's, Ampere 125.4 Rockford Pro Audio front stage 9 batteries, Mechman Elite 370 alt Team DSS, Team Ampere Audio 2014 Meca Mod 3 TN State champ / 3rd place Mod 3 World Finals
MIKE-2U Posted September 10, 2012 Author Report Posted September 10, 2012 How low are you looking for? You should be able to play mid 20s no problem if you tune to 30 How low are you looking for? You should be able to play mid 20s no problem if you tune to 30 I don't have a certain freq. i want to reach, I don't plan to play 20 hz tones or anything but would like to play 20 hz for the FEW songs i have that dip down to it. This will be my first big setup and i want it to be a demo machine, but also be able to listen to when i drive to school 45+ minutes away. Hair tricks would be amazing. I think tuning at 30 Hz should do just fine. 2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable (2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <------- Needs more power those woofers will laugh at that turd
MIKE-2U Posted September 10, 2012 Author Report Posted September 10, 2012 My SP4's are tuned at 30 and slap hard. You will not be dissapointed in 14 cubes at 30 hz ? does it play a good range of music and freq's 2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable (2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <------- Needs more power those woofers will laugh at that turd
SWIFT Posted September 10, 2012 Report Posted September 10, 2012 My SP4's are tuned at 30 and slap hard. You will not be dissapointed in 14 cubes at 30 hz ? does it play a good range of music and freq's It does very well. Could even use less space if needed but I like mine the way it is. Peaks at 35 but is pretty flat from 25-50 2012 F250 Lariat 6.7, lifted on 22's and 35's 4 DSS Ethos 18's walled tuned low 2 Ampere Audio 7500.1's, Ampere 125.4 Rockford Pro Audio front stage 9 batteries, Mechman Elite 370 alt Team DSS, Team Ampere Audio 2014 Meca Mod 3 TN State champ / 3rd place Mod 3 World Finals
RAM_Designs Posted September 10, 2012 Report Posted September 10, 2012 12-14ft^3 with a 30hz tuning will work great with those subs if you're looking for a lot of low-end output. Ryan Miskin - owner of RAM Designs I have my PM's turned off, please email at <script data-cfhash='f9e31' type="text/javascript"> /* */</script> 2200+ designs since March 2011...
MIKE-2U Posted September 10, 2012 Author Report Posted September 10, 2012 So between 12 and 14 what should i aim more for? 2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable (2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <------- Needs more power those woofers will laugh at that turd
RAM_Designs Posted September 10, 2012 Report Posted September 10, 2012 So between 12 and 14 what should i aim more for? Go larger if you're limited on power. Since you plan on running a 3500 to each sub in the future, I'd just go with a 13ft common chamber and call it good. Ryan Miskin - owner of RAM Designs I have my PM's turned off, please email at <script data-cfhash='f9e31' type="text/javascript"> /* */</script> 2200+ designs since March 2011...
MIKE-2U Posted September 10, 2012 Author Report Posted September 10, 2012 How would i go about portig it ?. Pm me a design or some info and i will order one from ya 2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable (2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <------- Needs more power those woofers will laugh at that turd
