bench Posted September 10, 2012 Report Posted September 10, 2012 Hi i was wondering if anyone can fill me in on a few questions i have about a few street stock rules fo DB Drag. !. i currently have a Mojo 2000d rated 2000 watts at 2 ohms at 13.8 volts I'm wondering if this is an acceptable amp because it also has a rating at 2400 watts at 15.5 volts. 2. can i do more then a single run of ground and power to compete? Any help is greatly appreciated Thanks
stevew007 Posted September 10, 2012 Report Posted September 10, 2012 Hi i was wondering if anyone can fill me in on a few questions i have about a few street stock rules fo DB Drag. !. i currently have a Mojo 2000d rated 2000 watts at 2 ohms at 13.8 volts I'm wondering if this is an acceptable amp because it also has a rating at 2400 watts at 15.5 volts. 2. can i do more then a single run of ground and power to compete? Any help is greatly appreciated Thanks well if its rated by the manufacture to do more then 2k i would say no then.BUT im no judge.as for the wire I have yet to see a rule about how much you can have. here is a good link about amps for street stock http://audioforum.termpro.com/vforums/showthread.php?t=150887
ALPINE408 Posted September 11, 2012 Report Posted September 11, 2012 its by the HIGHEST mfg rating if the mfg has a rating at 2400 watts listed i don't care what volts its a no go there is no rule on how many runs of wire so as much as you can fit while kepping STOCK APPEARNCE oh ima judge btw Have you ever had your woofers blown?
stevew007 Posted September 11, 2012 Report Posted September 11, 2012 its by the HIGHEST mfg rating if the mfg has a rating at 2400 watts listed i don't care what volts its a no go there is no rule on how many runs of wire so as much as you can fit while kepping STOCK APPEARNCE oh ima judge btw so are the local judges clamping amps out here?
sactownstang Posted September 11, 2012 Report Posted September 11, 2012 As of 2012: The rule is amps rated at no more then 2000w. Long as the rms stated by manufacture is not over 2000 watts your fine. Any rating above 2000w at any voltage or ohm level by the manufacture would deem the amp in violation of rule.
ALPINE408 Posted September 11, 2012 Report Posted September 11, 2012 no we are not clamping going by mfg specs Have you ever had your woofers blown?
stevew007 Posted September 11, 2012 Report Posted September 11, 2012 As of 2012: The rule is amps rated at no more then 2000w. Long as the rms stated by manufacture is not over 2000 watts your fine. Any rating above 2000w at any voltage or ohm level by the manufacture would deem the amp in violation of rule. no we are not clamping going by mfg specs you both should read this then http://audioforum.termpro.com/vforums/showthread.php?t=150887
stevew007 Posted September 11, 2012 Report Posted September 11, 2012 As of 2012: The rule is amps rated at no more then 2000w. Long as the rms stated by manufacture is not over 2000 watts your fine. Any rating above 2000w at any voltage or ohm level by the manufacture would deem the amp in violation of rule. so if i buy a dc 2k and it states 2400 on 16 volts that amp is no good even though im not using 16 volts?
ALPINE408 Posted September 11, 2012 Report Posted September 11, 2012 As of 2012: The rule is amps rated at no more then 2000w. Long as the rms stated by manufacture is not over 2000 watts your fine. Any rating above 2000w at any voltage or ohm level by the manufacture would deem the amp in violation of rule. no we are not clamping going by mfg specs you both should read this then http://audioforum.te...ad.php?t=150887 i have read that we watch the list of amps that are deemed illigal after being clampped but sorry unless wayne or you buy us a clamp meter it is not a requerment for us to do so and yes if it has a listed rating of 2400 watts at 16 volts even if your not using 16 volts its no good remeber this is a class for for the small wallet or new compitors that have not done the whole go big or go home mind set yet Have you ever had your woofers blown?
