LivinLows Posted September 11, 2012 Report Posted September 11, 2012 Hey guys i have an fi btl 18 i am planning on putting in my ext cab 2000 toyota tacoma. i will be running it at 2 ohms on a memphis mojo 4,000 watt amp so i should be putting 2000 to the sub. i will be listening to mostly rap with LOWS. i measured the back of the cab and can make about a 7cuft box without going above the bottom of the back window. will that be big enough? how many hz would you recomend tuning the box to? i will be posting exact measurements soon to get help building the box. i have experience with ported boxes but i want to make sure this one is perfect. thanks.
SnowDrifter Posted September 11, 2012 Report Posted September 11, 2012 Lows - 30hz or so. LOW LOWS - 27hz or so. Normal listening - 33-36hz. ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
